4l80e lost all gears... Need opinions
Old Jan 25, 2013 | 07:15 AM
KLUG'S SS's Avatar
FormerVendor
Originally Posted by 06murder
If your front pump is gone it want do **** sides rev up also. Might want check and see pump ok also.at first when I was reading your post OP,I was thinking of converter or pump. If converter fine I would check the pump next
This!!! ^^^^^
Seen this happen to a buddy's truck this past year. Driving down the road just cruising along everything fine and all of the sudden nothing, wouldn't move in any gear. Got it to the trans shop, pump took a crap.
May not be the pump but it's something I would definitely consider. It's easy to check to see if it is the pump too.
Old Jan 25, 2013 | 08:00 AM
Corvette432's Avatar
Originally Posted by KLUG'S SS
This!!! ^^^^^
Where is the front pump for the tranny located? Very curious now... Does the tranny have 2 pumps?
Old Jan 25, 2013 | 03:09 PM
06murder's Avatar
Remove the. Converter and its right behide it. Its the circle thing bolted unbolt it and press it out. Best way is to take the trans. Pan after unbolting pump and pry the pump out. Make sure you remove the lil prong on the input shaft and don't tear it.
Old Jan 25, 2013 | 08:20 PM
But does it have 1 or 2 pumps???
Old Jan 26, 2013 | 07:37 PM
KLUG'S SS's Avatar
FormerVendor
Their is a quick way to diagnose if a pump is bad in the trans. Pull off the transmission lines that are going into the radiator, get a container of some kind to point the lines into. Have a buddy get in the truck and start it, if the pump is working right you will have transmission fluid gushing pretty good out of the line. It will only being coming out of one line but I said to go ahead and pull both because I can't ever remember which one is the pressure line and which is the return back to the transmission just off the top of my head. Lol.
If its coming out at a pretty slow pace or just kind of dribbling out of the line or none may come out at all than it is the pump that is bad.
Make sure to have the truck running just long enough like maybe 5-10 seconds at the most to see if fluid is coming out of the line or not. I say this because if fluid is gushing out you don't want to run the transmission too far down on fluid while you are doing this little test.
Old Jan 26, 2013 | 07:41 PM
06murder's Avatar
Oh yeah I forgot that one! Klug good thinking
Old Jan 26, 2013 | 08:22 PM
KLUG'S SS's Avatar
FormerVendor
Yeah it's not a real "technical" way of diagnosing it because the transmission shops can just hook up their nice fancy gauges to be able to tell. But this shade tree mechanic hillbilly way of doing it will get the job done of diagnosing it! Hahahahaha.
Old Jan 26, 2013 | 08:30 PM
06murder's Avatar
Corevette it only have one!.. klug whatever get the job done right!
Old Jan 26, 2013 | 08:40 PM
KLUG'S SS's Avatar
FormerVendor
You know the thing is a pump is kind of rare to go out but in the case of my buddy's 05 Silverado SS he went thru 3 pumps within the last year!! He took it to a different transmission shop and I think they finally got it right now but what a mess and costly. The other funny thing is up until the past year or so I have rarely heard of pumps going bad on 4L60 and 4L80 transmissions but within the last year besides my friends truck I have all of the sudden heard and read of other cases where pumps have been failing. Weird. Maybe it has been more of a problem over the years than I thought and I just hadn't paid much attention but now that I am more aware of it I notice where guys are having them go bad or what.
BigE
Feb 21, 2018 11:44 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
mitchellmade
Sep 27, 2015 08:25 PM
Justin87gn
Sep 10, 2015 12:06 PM
