running airlines/drops in my garage for air compressor, is PVC ok?
Old Apr 29, 2010 | 12:17 PM
BlackGMC's Avatar
Resident Retard
Default running airlines/drops in my garage for air compressor, is PVC ok?
I will be installing a new air compressor tomorrow and I was wanting to add a couple of drops throught out the garage. I was wondering if PVC pipe would be OK to use.
Old Apr 29, 2010 | 12:50 PM
Zick's Avatar
No, it's brittle and when it breaks it shatters. Nothing says fun like plastic shrapnel.
Use PEX or Copper.
Old Apr 29, 2010 | 12:51 PM
BlackGMC's Avatar
Resident Retard
Whats PEX?
Old Apr 29, 2010 | 12:56 PM
Zick's Avatar
PEX is cross-linked polyethylene.
Mainly used for water lines or hydronic heating. But lots of people have used it for air lines.
Just check the PSI rating cause there are different types of PEX available with different PSI ratings.
It's also priced fairly reasonable.
Old Apr 29, 2010 | 01:00 PM
Phantom's Avatar
11 Second Club
we used pvc in tylers new shop and it works great
BlackGMC's Avatar
Resident Retard
interesting, i will check it out. do you glue the connections together or use some other way of connecting it?
Zick's Avatar
Here is just one of the many threads at Garage Journal about using PEX for air lines.
http://www.garagejournal.com/forum/s...d.php?p=583966
Old Apr 29, 2010 | 01:21 PM
Phantom's Avatar
11 Second Club
just used regular ol purple glue cory. really works out great...i had my doubts too, but we're both pretty hard on **** and have yet to break anything in the system. it lasted through our cold *** winter in a REALLY cold shop
Old Apr 29, 2010 | 01:24 PM
BlackGMC's Avatar
Resident Retard
ya my father had some PVC lines in his old garage for years with no issues, but he was sure to release the pressure when he was not using it... PVC is cheap and easy to work with, i think i might go with PVC, then again i might go check out that PEX stuff at home depot on the way home today.
Old Apr 29, 2010 | 01:30 PM
Phantom's Avatar
11 Second Club
i think tyler has a total of <$50 in his air system. really works great
