Need a good tranny jack
Old May 29, 2008 | 12:27 AM
  #31
thunder550's Avatar
High on diesel fumes
Here's the trans on the new floor jack. Casters are small, but they seem to work fine. Seems to be decently stable with this large load on it...likes to sway a little bit but it should be fine.
Old May 29, 2008 | 12:31 AM
  #32
2005 Silverado's Avatar
SPAM HUNTER
Those casters could most likely get swapped out for stronger ones though, it looks like they are all just bolted on.
Dustin
Old May 29, 2008 | 12:39 AM
  #33
thunder550's Avatar
Dustin
But they work fine....
Old May 29, 2008 | 11:38 AM
  #34
53RUSSELL's Avatar
If you set the arms in the corner of the pan and you use a tie down strap it will stay in place. I've used mine a lot know issue with it.
Old May 29, 2008 | 11:45 AM
  #35
SPAM HUNTER
I am just saying IF, its never bad to think ahead, come one chris!
Dustin
Old May 29, 2008 | 03:20 PM
  #36
ForcedTQ's Avatar
What is required to remove the trans and transfer-case together? Just remove the exhaust y-pipe, trans cross member? Procedure that works best for removal? Nice jack! I might have to pick one of those up.
Old May 29, 2008 | 03:26 PM
  #37
thunder550's Avatar
Well since my engine is out I was able to do it by just removing the trans crossmember because I could slide everything forward enough to clear the torsion bar crossmember. With the engine in, you'd have to remove the torsion bar crossmember as well. I would not have attempted this with the engine in....it's easier to remove the t-case first, then the trans IMO. If you ask others they may tell you differently.
Jakejack
Jan 8, 2024 10:44 PM
zblee
63
Jun 10, 2023 01:25 PM
Oobray
Jun 13, 2022 03:38 AM
DrX
Aug 19, 2015 04:45 PM
Chiphead
Jul 13, 2015 10:16 PM
