Need a good tranny jack
Old May 28, 2008 | 05:12 PM
thunder550's Avatar
High on diesel fumes
Default Need a good tranny jack
Well apparently the cheap Harbor Freight trans jack I got doesn't like the weight of a 4L80E, converter, and transfer case bolted together. It tried to collapse on me last night and made for a very frustrating trans removal that involved a tranny tipped almost on it's side and wedged between the torsion bar crossmember and front diff yoke.
Anyway, I need a GOOD heavy duty trans jack to use on the floor. What have you guys had good luck with?
Old May 28, 2008 | 05:19 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by thunder550
Harbor Freight
theyre only good for tape measures and screwdrivers man
2005 Silverado's Avatar
SPAM HUNTER
Here chris, its harbor freight, but a little nicer
2000LB capable
http://www.harborfreight.com/cpi/cta...temnumber=4075
1200LB
http://www.harborfreight.com/cpi/cta...emnumber=91020
800LB
http://www.harborfreight.com/cpi/cta...temnumber=3185
I am going to get one of the 800 LB ones
Dustin
Old May 28, 2008 | 05:24 PM
thunder550's Avatar
This is the one I had
When you crank on the screw to raise the jack it raises off-center....right side raises faster than the left, which makes it want to tip over.
I've been happy with the huge floor jack I got from them so far...I wonder if their hydraulic tranny jacks are decent quality?
Old May 28, 2008 | 05:27 PM
454navyss's Avatar
cant you get a tranny attachment for floor jacks? might try that....or make one for your floor jack
Old May 28, 2008 | 05:28 PM
thunder550's Avatar
I was just looking at that actually. They have this for $40. Would be cheaper than buying a $250-300 tranny jack.
Old May 28, 2008 | 05:30 PM
53RUSSELL's Avatar
Chris I have this one
Let me know if want ot borrow it.
I use this thing alot best this i could buy.
Old May 28, 2008 | 05:34 PM
53RUSSELL's Avatar
I don't like the way that thing looks. Would those point things pock a hole in your pan if it was to big?
Old May 28, 2008 | 05:35 PM
thunder550's Avatar
I dunno...I don't think either of their trans attachments will work with my jack unfortunately. I may go for one of their hydraulic units like Aaron has.
SPAM HUNTER
I believe that fits in the round pilot hole of a jack, that would work good with your big as jack chris but i dont know about jacking it up under the truck.
Dustin
