TrailBlazer SS Suspension | Wheels | Tires | Drivetrain |Engine | Body | News
Few TBSS Questions
Old Jan 27, 2009 | 06:23 PM
03sierraslt's Avatar
Default Few TBSS Questions
First off is anyone running the following cam from Speedinc? I like the specs on it, just looking for a mild street cam to use with stock converter. 214/220 .559/.564 111.5 LSA Also what does it take to max the injectors on a LS2? Only looking at Cam, LT's and exhaust and CAI.
Old Jan 27, 2009 | 06:27 PM
maddboost's Avatar
Why wouldn't you want to put a stall in the truck? If you want to keep it streetable just go with something smaller like a 2800 stall.
Old Jan 27, 2009 | 06:36 PM
Its not mine, its my buddies shop truck. He wants to keep the stock converter, he is yanking the trans and building it and we are tossing around some different setups for exellent streetability, fairly mild but healthy.
If it was mine and I was using it as a daily I would want the stock converter as well. I know my truck gets annoying to me driving in the city.
Old Jan 28, 2009 | 12:41 AM
maddboost's Avatar
What size stall are you running?
Old Jan 28, 2009 | 04:51 AM
Pi 2800-3000
However like mentioned this is not my TBSS and its keeping the stock stall. My truck runs a hell of a lot better compared to running the stock stall but thats not the point.
Old Jan 28, 2009 | 09:25 AM
andrew383's Avatar
traveling mod
you could pickup a I6 verter from circle-d.go check um out,he's done 3 GB in a row on tbssowners dot com.
ive got one forsale btw
i did a quick search over there and didnt see anybody runnin that cam
Old Jan 28, 2009 | 12:13 PM
The question is not concerning the converter, the guy that owns it has a tranny shop and also built my tranny. He knows what he wants to do tranny wise and the stock converter is part of it. More so I am just trying to get a idea of what is being used in the TBSS cam wise and how people like there setup. Looking for something that is a good over all improvement without giving up any drivablility. Originally the comp 212/218 came to mind being as though it is a solid performing cam, while on the small side for a LS2 it has proven to post good gains across the board hp and tq wise. I stumbled onto the cam listed above at Speedinc and it looked like it would be a nice cam, should have a bit more lowend then the comp 212/218 and yet should pull well up top. Just thinking out loud I quess.
Old Jan 28, 2009 | 03:55 PM
DOMLS2's Avatar
the zo6 cam works really good in the trucks when it's n/a.just tune the truck after the cam and CAI and it will be fun the drive.
Old Jan 28, 2009 | 05:29 PM
Stock LS2 cam is basically the same as the 01 Z06 cam. 02 Z06 has a little bit more lift but not enough to make it worth while IMO.
Old Jan 28, 2009 | 09:01 PM
mwalls54's Avatar
Need More N2O Mod
I would say that cam would make some good numbers but wouldn't be as fun to drive around with a 111 lsa and a stock converter. Because they are pretty much dogs out of the hole. at least mine is. it usually takes heads/large cam/intake to max out injectors. Even though he wants to keep a stock converter i would suggest a stock in-line 6 converter. It will stall a little higher than the stock which will help driveablility with the cam. But will have the same mannerism of the stocker.
