TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
torque cam
Old Mar 11, 2013 | 01:12 AM
santoy956's Avatar
Default torque cam
My set up is fbo 4:11s and tb stall, I am currently running a 224/230 581/588 on a 114 lsa cam..I like the top end it gives but my low end sucksssss!!!! I need some thing that will help me out through all my rpms...I offroad and tow now
Old Mar 11, 2013 | 01:34 AM
TDFDiesel's Avatar
I'm not going to be helpful, but what engine do you have?
Old Mar 11, 2013 | 01:40 AM
santoy956's Avatar
4.8 and stock 799 heads
Old Mar 11, 2013 | 09:19 PM
darnie's Avatar
212/218 low lift cam. will work good with a stock/ mild stall great low range and helps across the mid and upper too.
Old Mar 11, 2013 | 09:49 PM
GREENSIERRA's Avatar
you need WAY more converter for that cam
Old Mar 11, 2013 | 10:04 PM
santoy956's Avatar
How would a 3600 work for offroad and towing...and street & strip
Old Mar 11, 2013 | 10:07 PM
Richardman1992's Avatar
3600 is waaaaayyyy too much for towing or offroading. And the cam is too big for a 4.8
As Darnie said, 212/218 low lift and a 2800 at most stall. That's what I've got in my truck and it pulls like a freight train from 2k up
Old Mar 13, 2013 | 10:13 AM
shaw_426hemi's Avatar
What kind of off roading are we talking? Like you mudding or your driving off road in fields and such for hunting or some purpose similar to that? A higher stall would probably be ok if your off roading is not mudding or trail rolling at slower speeds, but if your more serious on the off roading aspect. These guys are correct. If your using it as a truck and mild off road a 3600 is a bit high I would think. Some guys tow with 3600 tho, don't think i would want to but im going with a 3200 and I off road (mainly driving in fields and BS for hunting) and i tow (5-6k lbs). I'm also going with a triple disk 10.5 inch converter tho.
Old Mar 13, 2013 | 03:32 PM
santoy956's Avatar
Mostly ranch roads and sand when I go fishing at the beach...I was looking the 210/218 vinci cam
Old Mar 13, 2013 | 11:34 PM
mcfarlnd's Avatar
Un-Registered User
Why low lift? Why not something with low duration and higher lift?
