TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Max MPH in 4x4
Old Feb 12, 2007 | 01:11 PM
xsports33's Avatar
Default Max MPH in 4x4
Is there a max MPH you should be driving at with 4x4 engaged. I know AWD have different suspension geometery to handle high speed with all 4 tires loaded, but what about 4x4 on dry pavemnt in a straight line, no turns.
Kind of like dragging in 4wd, but at what is the max speed the front axle can handle?
Old Feb 12, 2007 | 01:18 PM
kbracing96's Avatar
I've ran my truck to just over 100 mph in 4x4 at the track before without any problems. If it's autotrack 4x4 (push button), everything is always turning anyway, there just not coupled.
Old Feb 12, 2007 | 01:36 PM
PMCSPIDER's Avatar
that's pretty damn fast for 2wd mode, on any surface. I wouldnt go much faster than 40 mph. If its lifted forget it, you role that SOB if your not carefull. Unless you have geo tracker, but we dont talk much about that stuff on here as of late.
Old Feb 12, 2007 | 01:52 PM
xsports33's Avatar
Ever since the got the Radix installed i've been messing around with the "thrill factor". It was raining the other day and i gunned it and spun the rear tires, so i put it in 4x4 and gunned it again and took off but at around 85MPH-ish i started to hear a funny sound coming from the front axle. I didn't know if this was normal at high speeds or if i was hearing my 4.56s being noisy or what.
Old Feb 12, 2007 | 01:59 PM
Kingpimp's Avatar
I've had my truck to 70-75 in 4wd a few times, but on ice if that makes a difference. Most of the time, it's in auto 4 at those speeds though.
Old Feb 12, 2007 | 04:08 PM
P.O.R.N.'s Avatar
I drag race mine in the dunes in 4low up to about 50 55 at 6000rpm
Old Feb 12, 2007 | 06:07 PM
tenshikurai's Avatar
I've run mine as high as 85-90 on the highway in 4x4. It's definitely noisier with it engaged, but I've had no issues.
Old Feb 12, 2007 | 06:17 PM
dewmanshu's Avatar
Moderately Differentiated
I wonder what parish8's highest trap speed was...120-130ish maybe?
A little more noisy, but been to 120 on the highway in 4wd quiet a few times myself. Not as quick as parish...LOL...but I been up there. LOL
Old Feb 12, 2007 | 06:22 PM
dirt track racer 81's Avatar
thats what i was thinkin..parish traps a 13X mph i thought and he's in 4wd
Old Feb 12, 2007 | 06:32 PM
thunder550's Avatar
High on diesel fumes
Yeah as long as you're not turning I see no problem with any speed in 4wd....like kbracing said, everything is turning anyway, it's just not locked together.
