funny noises and synchros
OK guys I have two questions for ya! 1 where can I get a set of vette synchros for my 4L60? #2 I just got my truck lifted and I and getting some rather loud knocks from the front end when I go into reverse with the wheel turned and some time in drive with the wheel turned. It was alligned the day after the lift went on, and i have gone through the whole front end and double checked every nut and bolt and not a one is loose. Any ideas on either would be greatly appreciated!
[IMG]
[/IMG]
[IMG]
[/IMG]
you can get the servo from here: nonsponsor link
As for the popping noises, they could be coming from either your ball joints or your alignment being maxed out.
sounds like your cv axles. when your tbars are maxed out "which sounds like they are because of the alignment maxed" your cv axles are put in a bind and will pop and make noise. lowering the front end would help fix this. With those angles your cv axles wont last very long.
as for the servos check with FLT. they cary a full line of tranny parts and are top notch
well my torsion bars arent' maxed, they are only about half way up. Alignment on the front is still a ways off from being maxed. However it is looking like the c/v is going to hell though. If it is no biggie, it will take no more than an hour and $90 to fix it!
lukn4trbl355
Oct 21, 2015 11:19 PM
jscherbs
Sep 30, 2015 07:54 AM
