TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
View Poll Results: Which would give me more lift?
Ford Torsion Bar Keys
58.33%
GM 2500 Torsion Bars with 1500 Keys
41.67%
Voters: 12. You may not vote on this poll
Ford Torsion Keys work on a GM Truck
Old Dec 28, 2007 | 08:26 PM
SHINER's Avatar
Default Ford Torsion Keys work on a GM Truck
are these compatible? Its for a 2001 Z71 Tahoe with a 6 inch superlift and super ride shocks with 35s. The front end is sagging alot after the install and want it higher in the front stock keys are not far from being maxed out, and one bolt is tighten much more than the other one.
If these will work, which year model keys do i get for it 2003? How much do they run at the stealership? How much lift gain over stock?
Old Dec 28, 2007 | 08:50 PM
SHINER's Avatar
or, would it be better to just get 2500 ton torsion bars instead?
Old Dec 28, 2007 | 10:56 PM
Onetogofast's Avatar
If I have heard correctly, you can get like 1.5'' out of the ford keys, have not heard anything about 2500 keys. You might just check a junk yard for them, stealerships will probably be high.
Old Dec 29, 2007 | 09:37 PM
andrew383's Avatar
traveling mod
chevy hd keys lift a chevy half ton. ill NEVER use a ford part on my truck!!!!
Old Dec 29, 2007 | 09:54 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
you got that wrong, 2500 Keys lower a 1500, 1500 keys raise a 2500, the only keys that will rise your 1500 is a leveling kit or ford keys. And if your brave enough to crank your ford keys enough you can exspect to get about 2.5 inches of lift
Old Dec 30, 2007 | 10:00 AM
SHINER's Avatar
Finished the install in 3 hrs. I had to do alot of trial and error and did one side at a time. I did it with no clamp or torsion unloader. Just unhooked the upper control shock, tie rod, sway bar and forced the lower control arm down as hard as i could with a friend under neath matching the pattern and voila! According to the tape measure i got 4" of lift in the front after replacing the worn out torsion bars with newer ones and Ford Keys. Truck Looks FANTASTIC now!
Old Dec 30, 2007 | 10:07 AM
04BlackGmc's Avatar
10 Second Club
please quit saying the wrong thing..
Old Dec 30, 2007 | 10:10 AM
04BlackGmc's Avatar
10 Second Club
Anyhoo...
i have ford keys for about 2 years no problems...
Old Dec 30, 2007 | 10:16 AM
SHINER's Avatar
Originally Posted by 04BlackGmc
Anyhoo...
soon of later im going to get some Hd bars and then i will install some 1/2 keys in order for more lift and with the stronger bar sagging wont happen as much.
I was going to do that but thought the other way around with Ford Keys and half ton bars was the ultimate way to go....time will tell lol or jsut when im sick of replacing torsion bars
Old Dec 30, 2007 | 10:19 AM
04BlackGmc's Avatar
10 Second Club
Well there is that way and this way too.
GEt some rough country torsion bars ment for 88-98 trucks..
for them to work in a NBS you will flip them side to side and front to back and then install..
good torsion bars for 200$
