TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
33's on z71
Old Jan 3, 2009 | 08:03 PM
Default 33's on z71
will i be ok runnin a 33x12.5 on a stock suspension 03 z71? thanks
Old Jan 3, 2009 | 08:22 PM
knuckles's Avatar
will rub a lot in the front.
Old Jan 3, 2009 | 08:25 PM
hmm guess im gonna have to do a lift then...damn
Old Jan 3, 2009 | 08:29 PM
SynergyV8's Avatar
Your question is somewhat misleading. 33x12.50's are not a realistic size for an '03 Z71 because none come with 15" wheels...which high flotation 33x12.50R15's are. Your closest off-the-shelf "33 inch" tire is a 285/75R16, which is more or less a 32.8" tall tire and 11.25" wide. Those do fit, and have been proven to fit by many on here. Plan on trimming the front valance corner off and if need be, crank the torsion bars a few turns to level the front. You should not rub if you have stock wheels...be they 16's, 17's or 18's doesn't matter.
Old Jan 3, 2009 | 08:30 PM
knuckles's Avatar
just get a set of lift spindals and you will not have a problem with those tires. are you 2 or 4 wheel drive?
Old Jan 3, 2009 | 08:31 PM
sorry they will be on 17's and 4x4
knuckles's Avatar
you can get 33x12.50 for a 17" rim.
Old Jan 3, 2009 | 08:33 PM
yeah they r the nitto mud grapplers
Old Jan 3, 2009 | 09:01 PM
StrokerAce03's Avatar
You'll need Ford torsion bar keys and longer shocks. $50 for the keys and the shocks are up to you. Even then it might rub a tad depending on the offset of the wheels.
A buddy of mine had 34's on 17x10's and they cleared with the stock keys maxed and minor trimming.
Old Jan 3, 2009 | 10:26 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
theres people that cleared 33 with stock keys maxed out and alittle but of trimming, I got 35s on a body lift and I dont rub at all
