New component speaker install questions
Old Sep 11, 2019 | 07:50 AM
sleepybob's Avatar
Registered User
Post New component speaker install questions
I have a 2004 LS Silverado 1500 cc and I am updating the stereo and speakers. The truck does not have a Bose system or factory amp that I have been able to locate. I popped of the driver and passenger door panel and noticed there is already a component setup installed.My question is can I direct wire the tweeter and the driver into their respective wiring without using the aftermarket crossover? If I need to use the aftermarket crossover where is the main input wiring that needs to be used located? Thanks for the assistance.
Old Sep 11, 2019 | 08:12 AM
madmann26's Avatar
Spend the time and do it right.
You can reuse the factory tweater housing. I used my RotoZip to cutout the housing so my new tweeters would fit. I used baffles for the midranges. The passive crossovers are in the kickpanels, NOT the doors.
When I did mine, I ran RCA cables to my amps in the back, then wiring from the speakers to the amp. I soldered every connection where I had to add to my wiring.
Old Sep 11, 2019 | 08:24 AM
sleepybob's Avatar
Registered User
Thanks madmann26 for the input regarding the mounting but my focus was regarding the wiring. If I use the factory wiring will I need the use the aftermarket x-over or did Chevy wire the truck with some form of x-over already since there is a factory component system currently installed? If I need to use my own x-over where and which set of wires are the "main input" speaker wires prior to breaking off to a sub and tweeter?
Sexyrado327
Feb 20, 2018 02:50 PM
TXjeepTJ
May 24, 2014 12:08 PM
zeake
Dec 2, 2012 08:42 PM
Blu99T/A
Aug 27, 2008 06:38 PM
bigd16
Dec 3, 2007 01:06 PM
