8000k Hid question
Old Mar 13, 2010 | 12:34 PM
GJonas24's Avatar
Default 8000k Hid question
Hey guys i just bought a set of 55w 8000k hid from ddm tuning and got everything hooked up right and they wont turn on. Do i have to have a relay harness? Im at a loss. Thanks for the help.
Old Mar 13, 2010 | 01:04 PM
superchevyguy07's Avatar
where your headlight harness plugs into your ballast, you have to turn your plug around so that it plugs in backwards. Our trucks you have to reverse the polaritys. It should work then if everything else is correct
Old Mar 13, 2010 | 01:14 PM
GJonas24's Avatar
hmm i did that to both headlights and it only fixed my drivers side.
Old Mar 13, 2010 | 01:22 PM
GJonas24's Avatar
the only thing that i see is different is the drivers side has a small black box spliced into a wire from the high and low beam and it says quad beam in the middle and has an entry for the high beam wire and an entry for the low beam wire. Any idea what this is?
Old Mar 13, 2010 | 02:44 PM
2004SSS's Avatar
daym 55w on stock wiring ? thats alot of draw on the stock wiring .
Old Mar 14, 2010 | 10:13 AM
GJonas24's Avatar
i have that relay harness on the way
Old Mar 14, 2010 | 01:20 PM
GJonas24's Avatar
well now i know its not the hid. today i switched the bulbs and the drivers side was still the only side to work. so then i went to put my stock headlights back in and my passenger side still isnt working. any ideas what this could be?
Old Mar 14, 2010 | 01:30 PM
_zebra's Avatar
makes children cry
stock 9006s are 55W & Denalis use 9005s on the same wiring and they're 65W, i believe
Old Mar 26, 2010 | 06:19 AM
chrissch1's Avatar
Registered User
the relay will solve your troubles. i have a 01 silverado with 12000k .the relay kit only uses the driver side stock wires and gets the power straight from the battery .if you have the high beam hid's you might wan't to do the high 4 mod because there is @ 3seconds till the high beams are full on and you will be left in the dark for that 3 seconds look up the thread( headlight mod for $1) if you can't find that thread let me know and i will tell you how to do it
Old Apr 3, 2010 | 12:45 PM
04R3G3NCY's Avatar
i had trouble with blowin fuses at first..might want to check that. if it is consistently not wrking with bulbs/ballast that you know are good..but double check the bulb/ballast that was on the non working side originally to confirm they are good.
Texas5.3_1251
Mar 5, 2016 08:10 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
the owl
Sep 4, 2015 04:09 PM
