Pinstripe Removal
Old Oct 26, 2012 | 05:14 AM
C Gregory Purbaugh's Avatar
Default Pinstripe Removal
Hey guys, anyone here used one of those pinstripe remover disks? Is there a danger of damaging the paint? Or, is there another method I should use?
Old Oct 26, 2012 | 05:18 AM
Three6GMC's Avatar
You talking about the eraser wheel? I have used it countless times on trim pinstripes and emblems. Works great just makes a BIG mess. Doesn't harm the paint at all. I would use that before going to any kind of solvent or something like that. The wheels can be bought at the auto parts store for about $30 I think but last a long time. Just use any normal drill and does the job great. What I have done is used the eraser to get almost everything off and go with a detail spray and a micro fibre towel afterwards to get any left over residue.
Old Oct 26, 2012 | 05:20 AM
Can they be used with a regular power drill, or do I need an air gun?
Old Oct 26, 2012 | 05:24 AM
Three6GMC's Avatar
Just a reg cordless drill will work... Nothing special is needed at all. You will see it doesn't take much speed or effort for it to work. Really easy. Moderate pressure is all that is needed too, you don't have to put a lot of force. Once you try it and get a feel for it you will see what I'm talking about and how easy it is.
Old Oct 26, 2012 | 07:57 AM
abey15's Avatar
What i did is run a heat gun over what i was removing then run the wheel over it while it was warm. Works amazing! Be careful with the heatgun lol
Old Nov 9, 2012 | 07:51 PM
TG02Z71's Avatar
Used a hair dryer on mine, it was safe but a pain but really not all that bad I guess.
Old Nov 10, 2012 | 10:09 PM
slonlow2000's Avatar
You can build up to much heat and burn the paint with the wheel if you've never messed with before. Just dont stay in 1 spot to long. I normally pull them with a hair dryer and just clean off the glue left behind with wax and grease remover.
Old Dec 11, 2012 | 02:57 PM
FLREPOMAN's Avatar
yes it makes a mess i have one and its a royal pain just use a heatgun or in some cases some laquer thinner
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
