nbs 07 suburban door panel removal
Old Jul 6, 2008 | 05:08 PM
v8
17,16,15,14,13,12,11 Drvr
Default nbs 07 suburban door panel removal
Bought some color matched door handels for the sub. but can't for the life of me figure out how to get the inside door panel off, the older ones were easy as butter, any help?? thanks.
Old Jul 6, 2008 | 11:28 PM
VroomVroom's Avatar
I haven't tried as yet, but I'll take a peek tomorrow. I kind of thought the older ones were a pain in the butt, so we may have differing thoughts.
Old Jul 7, 2008 | 06:00 AM
v8
99-07 3 screws and pull up and its out hahaha, now the nbs not sure.
Old Jul 9, 2008 | 08:25 PM
v8
Damn nobody hahhaa
Old Jul 10, 2008 | 12:29 AM
BLK WDO's Avatar
take a trip to a chevy lot and ask a worker there. if they are not dicks they should tell u atleast.
Old Jul 13, 2008 | 12:26 PM
spitfire2332's Avatar
I know this wont be the same for a suburban, but this is for the trucks, I assume most of the bolts should be in the same area. http://www.gmfullsize.com/forum/showthread.php?t=93769
Old Jul 13, 2008 | 11:39 PM
chevytruckguy's Avatar
Its been a while since I've pulled mine. There is a hidden screw behind a small 1"x4" cover panel, inside the armrest. Pry out the cover panel and you'll see the screw, I think its a 10mm. You'll have to remove the lock **** with a small screwdriver or pick, there's a lock tab you have to undo. Be careful its easy to break. Pull the mirror cover, it makes it easier, but you might not have to. Then at the bottom of the panel start pulling away from the door. You have to pull pretty hard. Theres about six or seven if I recall. Good luck. The handles are really easy to change out once you get the panel off.
Old Jul 17, 2008 | 09:03 PM
v8
Thanks!!!
rumblebox
Oct 29, 2015 10:35 AM
Justin87gn
Sep 10, 2015 12:06 PM
screaminian47
Sep 7, 2015 08:20 PM
the owl
Sep 4, 2015 04:09 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
