LED dash swap install instructions: 03-08 Classic Silverado
Old Jan 8, 2013 | 07:44 PM
  #141
Tootall's Avatar
Originally Posted by Gilbert Gilly Ybanez
Where would I get the bulbs for he conversion?
ebay ! or find an electronics store
Old Jan 11, 2013 | 12:33 PM
  #142
_zebra's Avatar
makes children cry
we all know the twistlocks from superbrightleds are keyed incorrectly & don't make good contact without untwisting them halfway, so what have some of y'all done to mitigate that? half my lights trun on & off when bumps/vibrations jar the minimal connection
Old Jul 4, 2013 | 04:00 AM
  #143
ak2007r6's Avatar
great thread.. will be coming back for directions hopefully in the future when I get the next truck.
has anyone done the orange? Curious how that looks
Old Jul 7, 2013 | 11:30 AM
  #144
kelz214's Avatar
Originally Posted by Static54
Hardest one so far:
did a full led conversion for my cluster panel now i need help with the AC controls can't get them to turn on after the swap
Old Jul 18, 2013 | 05:10 PM
  #145
splash07s's Avatar
How about the Headlight switch, how does the LED attach to the circuit board? Do you replcae the bulb in the removable housing or just go straight to the board? And which terminal is positive on the board?
Edit:
OK I got an LED on the board and figured out which side is positive. I hooked everything up and its pretty dim once all the trim and face plates get put back on. Waiting to see how it looks after the sun goes down.
Old Jul 18, 2013 | 07:00 PM
  #146
splash07s's Avatar
OK all the LED's i put in work but they are dimmer than the stock bulbs, whats up with that. I used 5mm dome top green LED from radio shack with a 470 resistor. Any suuggestions?
Old Jul 19, 2013 | 03:55 PM
  #147
Tootall's Avatar
Edit:
get creative. . . . I have 4 of them on mysetup
The "reflector" on the inside is made to spread he light
Old Jul 19, 2013 | 04:15 PM
  #148
splash07s's Avatar
I mean they are really dim. Dimmer than stock bulbs. In going to try a different color and see if it works.
Old Jul 24, 2013 | 08:47 AM
  #149
splash07s's Avatar
bought these - the first flat top blue ones on the list
5mm Super Bright flat top LEDs from Leading-LEDs.com - Your Source for High Quality, Low Cost LEDs
Hoping to get them installed tomorrow and see how they look.
Old Jul 25, 2013 | 12:32 PM
  #150
splash07s's Avatar
OK got em on and they are superbright and awesome! I also think I may have figured out how to light up the dimmer symbol at the bottom of the dimmer wheel. I drilled a small hole in the dimmer plaastic housing, then soldered in an LED to the posts the orginal bulb ran off of. I forgot to put a resistor in and I would recommend it cuz I blew the first LED out when I hooked it up to power. I need to extend the LED just a bit to get it in the hole though, but you guys get the idea.
