LED dash swap install instructions: 03-08 Classic Silverado
Old Dec 1, 2011 | 03:55 PM
  #131
Tootall's Avatar
Originally Posted by Forcefed81
Can anyone tell me if the bulbs on the radios are also wired in series? Thanks for the help.
yes they are . . . but still use a meter to double check. I've done 5 radios, and not all are the same. Meaning TB SS dash vs the LT dash on trucks, vs the trucks
Old Dec 1, 2011 | 06:56 PM
  #132
Crewcabsilverado's Avatar
Registered User
Originally Posted by Tootall
HVAC - Digital (automatic) controls. (easiest to do, easiest to burn)
You can use all blue or do blue and red.
Take a 5mm socket or the needle nose vise grips to the 4 screws located on the back. Pull off the black ***** and then you'll see the circut board. Here's a few pics with the LEDs mounted.
are you using a red led and a blue led behind the temp dial??
Old Dec 18, 2011 | 04:31 PM
  #133
Rob Beschta's Avatar
Registered User
I want to do this to my 00, what is the difference? Do i still use the same LED's and resistors?
Old Dec 20, 2011 | 08:24 AM
  #134
Static54's Avatar
Yes. Difference LEDs may have a different current rating which in turn would mean you'd have to adjust the resistors accordingly.
Resistance= Volts / Current
Old Dec 20, 2011 | 09:03 AM
  #135
Registered User
Thanks!
Old Jan 31, 2012 | 07:14 AM
  #136
mxg286's Avatar
Does anyone know what the supply voltage for the factory lighting for a 2003+ silverado? I was using a resistor calculator because, as I wanted to find the required resistor for orange leds.
Has anyone done the orange led's? Super bright sells them but they are only 15 deg for the 3mm, has anyone found wider angle orange?
Old Jan 31, 2012 | 08:15 AM
  #137
Static54's Avatar
Most likely 5 volt. You can measure with a meter. You may need one any how to find polarity. Not sure on orange seems like you may eat to double them up. Be sure to let us know how it goes.
Old Feb 18, 2012 | 02:54 PM
  #138
Prolong's Avatar
ima have to do this soon
Old Oct 17, 2012 | 09:31 PM
  #139
Gilbert Gilly Ybanez's Avatar
Registered User
How much for a conversion on a 06 Sierra cluster AC controls and steering wheel??
Old Jan 8, 2013 | 12:55 PM
  #140
Registered User
Where would I get the bulbs for he conversion?
