Headlight Mod for $1
Old Jan 3, 2011 | 05:18 PM
  #231
Wink1506's Avatar
Registered User
Thanks for all the info about 4-High. This has been a lot of help. I've got a 2000 silverado and my next task is to get my drl's to stay on at night along with during the day. I wanted to know if there is a way to tie them into my parking lights. If there is an easier way... or if anyone knows how please help me out.
Thanks
Old Mar 12, 2011 | 09:31 PM
  #232
VegasSierra's Avatar
Registered User
Originally Posted by Tyglon
I have a 2001 2500hd silverado and want to make my fogs on all the time the lights are on. I did the high 4 ground out mod and it works great. But I'd like my fogs to stay on when I go to highs. Looked this tread over start to finish and didn't find an answer, or if I did it's above me so I didn't know it. I melted my fogs with the wrong bulb and now have amber running LEDs on lower valance and they turn off when highs come on. Kinda stupid. Any help. Thanks.
I too have read this entire thread, with no luck on how to have fogs with highs on the earlier models (Mine being 2000). Or did I miss something? TY
Old Mar 13, 2011 | 07:19 AM
  #233
TIM Z's Avatar
11 sec. Truck Mod
x 2
Have lows/highs/fogs all on on my 07 Dmax, want that also on my 2000.
Old Mar 18, 2011 | 10:11 AM
  #234
BrutalSierra's Avatar
I want to do this on my 2011 Sierra!!!!
Any help?
Old Apr 13, 2011 | 03:34 AM
  #235
GMC3's Avatar
If you guys really want your fogs on with your Hi-4 mod just wire your fogs to a rocker switch in the cab. Not as convenient but it is effective.
Old Apr 21, 2011 | 02:51 PM
  #236
TimDave217's Avatar
I thought having HIDS would make this different but it Works perfect on my 02 sierra, only thing i need to do now is wire it up so that the fogs stay on also when the hi-4's are on.
Old Apr 25, 2011 | 02:53 AM
  #237
piecesparts's Avatar
Any help?
I just got my 2011 Sierra and after reading this info, I want to do the same to mine. I have had all of my previous trucks wired to do the four headlights, but with the newer wiring systems I want to do it right. The idea of a diode makes it seem so simple. Has anyone done this on 2010 or 2011 model yet? Just want to do it right. Also, I have been thinking of an upgrade to the wiring harness and putting in a higher wattage set of lights.
Just keep Chooglin along!
Old May 15, 2011 | 05:40 PM
  #238
66impala4dr's Avatar
Registered User
i have a 01 yukon xl and i need to cut the wires to make the low and high beam work does anyone have a diagram im not really good with electric wires. would someone please help me out on this and show me.
Old May 15, 2011 | 06:04 PM
  #239
Registered User
Originally Posted by Raven02TA
ok so to make things clear....
if i want my fogs to come on during the daytime (brown line),
if i want my low beams to stay on when i use my high beams (blue line)
if i want my fogs to stay on when the low beams are on without having to use the button im assuming thats its still t4/b5 (brown line)
where is this conector located. on a 01 gmc
Old May 15, 2011 | 06:15 PM
  #240
Registered User
Originally Posted by KeukaZ71
thanks for the great article
on mine, i cut the yellow wire and grounded it to the body. you can see the passenger side with no mod, and driver's side with mod.
i have my fogs rigged to my stereo. if stereo is on, so are the fogs. wire taps are great
ok now explan it on how you did the fog lamps to the radio to make them come on. diagram would be good.
