Headlight Mod for $1
Old Apr 26, 2007 | 03:27 PM
  #111
04BlackSilverado's Avatar
Originally Posted by mdwatts11
Did this last week, never had any problems. I hooked it up so where every light on the front of my truck is on when I hit the brights. Man, it is bright as crap. My suggestion is that if you do it like 04BlackSilverado originally stated, make sure none of the diodes are touching. Also, make sure that they are in there all the way.
Yes tape over the bare conductor or use heat shrink. I did not, but I am crazy....
Originally Posted by cthotrodder72
Since 04BlackSilverado has had his done for so long and had no problems, i suppose there really isn't any reason to worry. So, when you buy some hi4 kit from PAINLESS or some wiring co. like that, why do they include a relay that's rated 30 amps?
The aftermarket kits manually turn on the high beams, that's why they need a 30 amp relay. The method that I posted uses the BCM to turn the stock relays, it just bypasses the requirement to turn off the lows when your turn on the high beams.
Originally Posted by NegraRCSB2X4auto
so if i do it this way do i still need a diode to just make my lows come on with my highs. or can i just run a wire from one red circle to the other. an no relay?
The method there is an alternative to mine, I am sure it will work, I just like mine cause its simple. The originator of that can post If he would like.
Old Apr 26, 2007 | 07:17 PM
  #112
cthotrodder72's Avatar
Makes sense. I figured it was something like that. I'll be doing this mod soon, that's for sure.
Old Apr 28, 2007 | 01:06 AM
  #113
1SlowHoe's Avatar
Destroyer of Transmissions
I did it the other day. Only took a few minutes. I had to figure out which end of the yellow wire to ground after I cut it but, then it was simple.
(the one coming off the light plug needs grounded so cut the yellow wire as far back into the grill as you can reach.)
Old Apr 28, 2007 | 03:28 PM
  #114
ChevyMan23's Avatar
I did mine today..after sitting on it forever....i did the under the dash method....also i have Sylvania Platinum bulbs or whatever they are in my signals and DRL's(the ones that turn on orange but go off kinda blusih).....so i set it up to when i turn my lows on the DRL's come on as well....along with the 4hi mod..pretty easy..and cheap...my favorite combo for everything...haha
Old Apr 29, 2007 | 01:52 AM
  #115
Chevy_Truck_Man's Avatar
Did mine as soon as I read the thread. No problems yet. It's freakin sweet. Truck in sig
Old Apr 29, 2007 | 08:41 AM
  #116
NegraRCSB2X4auto's Avatar
Yup it works just did mine in about 3 min. Thanks for this mod
Old Apr 29, 2007 | 09:47 AM
  #117
No Problem
Old Apr 30, 2007 | 01:15 AM
  #118
GBs_03's Avatar
8 HI for over a year and going strong.
Old Apr 30, 2007 | 03:55 AM
  #119
viciousknid's Avatar
Where's the Beef?
I'ma try this as soon as I get a chance. My question is this.
My truck didn't come with factory Fogs, If i install some, should i wire them into the box or splice them into the d/ls and just diode the d/ls to stay on with the lows and lows with highs?
Old Apr 30, 2007 | 05:55 AM
  #120
mdwatts11's Avatar
I installed OEM aftermarket foglights on my truck. As long as you used the gm harness, your truck is already wired for them up until the fuse block in the engine compartment. Just wire it in as stated at the beginning of the post and you will be good to go.
