Headlight Mod for $1
Old Dec 20, 2005 | 04:01 PM
  #101
04BlackGmc's Avatar
10 Second Club
i did it a little different but i have pics..
Well i figured it out yesterday In the most easy form.
You need some Jumper wires 1N4004 12 volt relay and some shrink tubing.
Ok see in the pic the Red circles Those represent where the jumper wires go. On the high beam and low both its the bottom right on both, then on the fog relay its the top left.
Now notice the blue circles thats where the major numbers on the relay need to be on the outside. 8567 and 8566 i believe in big letters are the numbers..The three relays you are jumping will be facing the opposite way of the others.
that is all now when you drive around you can have the low beams with fogs or without. When you kick on the high beams no matter what Low kick and fogs kick on (even if you didnt have em on before).:head:
Old Jan 7, 2007 | 06:00 PM
  #102
Red Heartbeat's Avatar
Just a note for those about to solder the diode to the relays... when soldering the jumper lead to terminals 85 to both relays keep the solder on the contacts to a minimum. If you install the relays and the high beam come on and then all four come on during the low beam selection, don't resolder the the diode the other direction, just switch the relays, high for low and low for high. This on the the 2004+ trucks of course. Also, this is just for the Hi4 mod, no jumpers to fogs or anything else.
Old Jan 7, 2007 | 08:18 PM
  #103
04BlackSilverado's Avatar
I need to update this and write a better write-up someday..........
Old Apr 8, 2007 | 02:30 PM
  #104
cpelton's Avatar
anyone have any problems with this? just did it yesterday works great!
Old Apr 8, 2007 | 06:17 PM
  #105
Mine has been in since before I started this thread and I have never had any problems.
Old Apr 25, 2007 | 12:01 AM
  #106
dkubricht's Avatar
finally did this mod. Holyshit its awesome. thanks alot guys
Old Apr 25, 2007 | 02:18 AM
  #107
Spoolin's Avatar
GFYS and STFU
Wow, why didn't this thread ever become a sticky...This is great info.
04Blacksilverado, great work and thanks for sharing. Hope you get that write up done before this thread dies again!
Old Apr 25, 2007 | 05:47 AM
  #108
mdwatts11's Avatar
Did this last week, never had any problems. I hooked it up so where every light on the front of my truck is on when I hit the brights. Man, it is bright as crap. My suggestion is that if you do it like 04BlackSilverado originally stated, make sure none of the diodes are touching. Also, make sure that they are in there all the way.
Old Apr 25, 2007 | 07:46 PM
  #109
cthotrodder72's Avatar
Since 04BlackSilverado has had his done for so long and had no problems, i suppose there really isn't any reason to worry. So, when you buy some hi4 kit from PAINLESS or some wiring co. like that, why do they include a relay thats rated 30 amps?
Old Apr 26, 2007 | 02:18 PM
  #110
NegraRCSB2X4auto's Avatar
so if i do it this way do i still need a diod to just make my lows come on with my highs. or can i just run a wire from one red circle to the other. an no relay?
