gauge install ques
Old Feb 19, 2005 | 09:02 PM
trimmen's Avatar
Default gauge install ques(snakeoiler)
i drilled 2'' hole in the cluster fore an auto meter trans temp gauge,but in order to let the gauge go deep enough i have to drill though the electrical panel board and there is some wires there that will be cut off.i see some on this site have done the install ,any help would be great.i don't want to ruin my cluster.01 gmc ecsb 4x4.dash is out and i'd like to put it back together.
Old Feb 20, 2005 | 10:51 AM
SnakeOiler's Avatar
you've gotta cut everything in order to do that. Just the nature of the beast.
I cut enough to clear the connections and bulb socket, but left enough for the hold down nuts.
Old Feb 20, 2005 | 01:51 PM
trimmen's Avatar
thanks snakeoiler.it looks like i might have to cut off two little connectors in order to clear the light connector hope it works,thanks again.
Old Feb 20, 2005 | 02:04 PM
SnakeOiler's Avatar
Originally Posted by trimmen
. . . it looks like i might have to cut off two little connectors in order to clear the light connector. . . .
Two little connectors? I'm at a loss of what you're speaking of?
Old Feb 20, 2005 | 06:16 PM
TrickyTransAm's Avatar
Theres more threads in here for the auto trans temp guage.
If your running aftermarket, theres also a thread down below in the list, which a member retrofitted it, and tells how he did it.
Theres also the pay to play over at US speedo...150 to put in a factory one, and reprogram the cluster.
C
Old Feb 21, 2005 | 04:32 PM
trimmen's Avatar
snakeoiler i think they might be resisters .i'm also wondering if all 2&1/16 auto meter gauges are all the same depth.
Old Feb 21, 2005 | 04:53 PM
SnakeOiler's Avatar
This here tells you of the dimensions: 2 1/16 dimensions
Do you have a picture of the connectors (resistors) you are talking about?
Old Feb 22, 2005 | 03:47 PM
trimmen's Avatar
i got it working without touching the resistors,it was very close though.thanks snakeoiler for your help & patience.
thunder550
Oct 8, 2015 04:53 PM
hartinclay
Aug 3, 2015 07:03 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
