IPC/DIC Circuit Draining Battery, need help.
Old Aug 2, 2015 | 07:20 PM
hartinclay's Avatar
Default IPC/DIC Circuit Draining Battery, need help.
Okay guys, I bought a used 03 SS with 117K, that is in immaculate condition other than the sad fact that it is having the battery drain issue from the IPC/DIC circuit. I did my research, and a draw test and found this to be the circuit. Will rebuilding the gauge cluster as most have suggested fix the problem or should I just break down and buy a whole new cluster. The speedo is reading weird anyways so I know I am going to get that fixed. I just dont wanna shell out the coin to have everything rebuilt and LED's installed only to have it not solve the problem. I found a few posts on other forums where some people had the cluster repaired and it fixed it and others that did the same and had the same problem. Ill be using the gm gauge guy if I go that route. What are your opinions on the matter, anyone else who has had this problem feel free to chime in. Thanks guys.
Old Aug 3, 2015 | 07:03 PM
Suburbazine's Avatar
Get a rebuilt cluster from fixmygauges, there was a software update to address certain cases where the cluster did not turn off after the key was removed.
RustyD
May 23, 2016 07:04 PM
Avalanche2002
Nov 30, 2015 07:31 AM
Wrecker 426
Sep 30, 2015 09:39 PM
Slammed silverado
Sep 28, 2015 06:14 PM
lxcoupe
Sep 25, 2015 12:36 PM
