Brake Upgrade Project (Completed 4.17.04)
Old Feb 19, 2004 | 12:28 AM
JSmith's Avatar
Default Brake Upgrade Project (Completed 4.17.04)
The brake upgrade project is underway and the truck is on jackstands.
I'm upgrading the stock braking system with...
1. EBC slotted and dimpled front rotors. $225 shipped from QTP.
2. Powerslot rear slotted rotors.
3. Earl's Hyperfirm 5 line Teflon braided/stainless brake lines. $145 shipped from Thunder Racing.
4. Hawk HPS brake pads (front & rear). $162 shipped.
5. Powder coated calipers and brackets. $175 local shop.
Other items needed for project:
1. GM caliper rebuild kit for each caliper. Contains seals and o-rings. Mandatory because the seals and o-rings will be destroyed during the powder coating curing process. $40 per caliper.
I'll be posting the progress here in this thread for those that want to follow along. Tomorrow the calipers come off and will be disassembled prior to being sent to get the powder coating.
Old Feb 19, 2004 | 01:44 AM
Tokez420's Avatar
good luck
if i ever get enough cash together im goin to be doin the following.
OEM rotors
hawk brake pads
motul brake fluid
i think thats it.
Old Feb 19, 2004 | 06:09 AM
BigKID's Avatar
How much is this package running you? I need to do something similar real soon.
Old Feb 19, 2004 | 10:36 AM
Dude, forget that stuff, get the Eradispeed for $500, on just the front, it will blow away your stock brakes...I treat mine like a race car and my brakes are freakin outstanding. $600 with shipping, bolts right on, can use stock pads, or for even more braking power get some Hawks, or EBC's on there, and it will stop harder than mine. Man, my seatbelts really gotta work when I slam on my brakes!
Old Feb 19, 2004 | 10:38 AM
RUINED's Avatar
baer is coming out with its aluma sport kit for trucks......sloted, drilled, calipers, $995 a set.........suppose to already be out but theres a hold up.........should release any day.......
Old Feb 19, 2004 | 12:21 PM
yellowls1truck's Avatar
Yeah, the Baer Alumasport kits come with PBR two piston calipers with pads front and rear. They are powdercoated red too. Im thinking about getting this along with some Earls 5 pc braided lines.
Old Feb 19, 2004 | 12:55 PM
RUINED's Avatar
i just called baer about my order and was told six more weeks......uuuhhhgggg.........PBR is lagging on the calipers.........and i believe that they come with pads..........but not 100%
Old Feb 19, 2004 | 06:59 PM
KeukaZ71's Avatar
i did my rears today. hope i didn't hijack your thread. i'll delete if you want
Old Feb 19, 2004 | 07:23 PM
red53gmc's Avatar
That's awesome.....until you want to go to the track with those 14" rotors, which require an 18" wheel.....I would love a baer brake package, but can't do it b/c I love the track more.
BTW, I just got an email from baer saying they don't offer any stock size rotors for the NBS trucks, only the 14" size.
As far as that $1000 package, is that plus one as well...meaning will it fit on anything other than an 18" or bigger wheel?
I guess I'll end up with some powerslots or ebcs.
Old Feb 19, 2004 | 09:18 PM
JSmith's Avatar
I'm rough estimating but I'm thinking it's going to run right around $650 but that's for everything in my initial list. I'll update my original post and put the prices up for each item.
