03 z71 drop
I know, buy a 2wd. Anyway have any of you heard of a drop yet for a reg cab short bed 1500 Z71. Bell tech and hotchkis don't offer one and won't according to their R&D departments. Hoping some of you may have heard of something. Do you think I can bag it?
Want to lift but have ruled that out too because I have the off road ride control option and all the vendors tell me I can't lift it because of this option. I already installed shackles anyway and will be taking out the block or helper spring this week.
The rear is the same as a 2wd except for the blocks that are under the leaf springs... so you can basically go as low as you want.
For the front, you can get different torsion bar keys which allow you to crank em down pretty far. It's only good for 3", but better than nothing.... Im doing this to my truck, i'll post up some pics soon.
I will be receiving my 20" Centerline Stingray III's in a few weeks and want to get the ride hight adjusted.
thanks
Larry
You will have rear driveshaft clearance problems, It is a Problem on the SS and it will be a problem on your truck as well. You are either gonna have to modify the crossmember or get a smaller diameter driveshaft made, if you look under your truck, you will see what i am talking about
