Yet another turbo build...
Old Nov 16, 2015 | 10:08 PM
  #401
Atomic's Avatar
I have a gauge for that
More power will make the clutches slip a little more during engagement. Pretty normal...
Old Nov 16, 2015 | 10:10 PM
  #402
GMCtrk's Avatar
It's not under power. I haven't shifted it at wot yet
Old Nov 16, 2015 | 10:42 PM
  #403
GMCtrk's Avatar
EDIT...decided I'm going to change the internal harness given ATF inside the connector rather than leave it as is. Gotta do things the right way to get right results.
I did buy a Delco internal harness to replace the current one ($39) since I know the seeping through the pins is not normal but I'm also suspecting it's at least partially due to the practice of overfilling the trans to prevent starvation.
Also, just a note, comparing logs from the track run in sig to 3rd gear highway pull on new setup. Peak Air/flow grams/cyl ...S475 = 1.85 S480 = 2.25
Old Nov 18, 2015 | 07:58 PM
  #404
BigKID's Avatar
Check your logs for calculated input torque and see if its lower now. You may be referring to lower shift pressure cells.
This is the first thing I thought of when I read the issue. It still makes sense with part throttle as a tighter converter will get up to speed with less throttle and rpm thus translating to a lower calculated torque. Don't immediately dismiss the idea just because it doesn't fit in with your line of though.
Old Nov 18, 2015 | 08:11 PM
  #405
03sierraslt's Avatar
Your peak airflow readings change anytime you alter the ve table. Just a FYI.
Old Nov 18, 2015 | 08:14 PM
  #406
GMCtrk's Avatar
Good point and noted. I'm still going to change the internal harness as fluid leaking thru the pins can't be good. Unfortunately, that means no track Friday, but I could still hit up the 1/8th on Sunday.
Also, I'm now truly maxed out on my injectors and basically maxed out on the 2.5 bar map. I've been in talks with Gagezited about a stock style 3 bar MAP. I would love to get this thing up to 25 psi. Upgrading to 1700 cc injectors is going to be a boat load of cash, but I just don't know of any way around that for hi-impedance injectors. At some point though the spending just has to stop. I just want that 9 sec. pass though.
Old Nov 18, 2015 | 08:17 PM
  #407
I forget, what is your engine setup again?
Old Nov 18, 2015 | 08:20 PM
  #408
GMCtrk's Avatar
stock 2002 6.0
Old Nov 18, 2015 | 08:38 PM
  #409
BigKID's Avatar
I looked back thru the thread and didn't see; Have you changed out the stock rails/regulator with aftermarket? Still on the 1000cc FIC injectors?
Old Nov 18, 2015 | 08:50 PM
  #410
GMCtrk's Avatar
Yes and yes to both questions. I'm still running stock fuel lines and filter from the firewall to the tank.
