Yet another turbo build...
Old Nov 28, 2015 | 09:00 PM
  #421
03sierraslt's Avatar
Well my 72's are pretty much maxed on gas so I doubt 130's will be enough an e85 for more.
Old Nov 28, 2015 | 09:02 PM
  #422
GMCtrk's Avatar
based on your trap you'd be fine with the 1000cc's on E85. But for the headroom and growth go bigger.
Old Nov 28, 2015 | 11:04 PM
  #423
GMCtrk's Avatar
Noticed a couple small drops of oil on the garage floor near the expected location of the engine/trans interface, haven't been under it yet...suspect oil blowing past rear main seal at high boost 22 psi. Thinking my pcv setup is ineffective at this level and need to go GeorgeC style, venting both VC directly to atmosphere with big lines. I need to do a search as see how Atomic did his.
Old Nov 29, 2015 | 10:15 AM
  #424
Atomic's Avatar
I have a gauge for that
Thats now known as GeorgeC style?
I had a breather on the pass side oil cap, PCV running from the PS valve cover to a T that connected to the valley cover. I drilled and tapped a 3/8" fitting there. Then the other side of the T to a vented catch can. I drilled out the DS valve cover PCV to 3/8" and added a second hole as well then Td together to the other side of the PCV.
A better way to do it would be with aftermarket valve covers that have 1" ports to vented can(s). If you dont use a can you will have oil mist go out of the filter.
Old Nov 29, 2015 | 12:15 PM
  #425
George C....'s Avatar
Formerly ScreamingL
Valley cover vented with -6
-10 or -12 off each cover into breather/catch cans and be done with it
Or spend good money and do a vacuum pump setup
More boost more venting and stock pcv lines arent large enough
Old Nov 29, 2015 | 12:16 PM
  #426
GMCtrk's Avatar
I'm gonna see if I can get -12 bungs welded to the valve covers. Would I be okay venting both sides into 1 catch can or should I do 1 can per side?
Old Nov 29, 2015 | 12:47 PM
  #427
Formerly ScreamingL
My first setup was 3 into 1
Now i run 2 catch cans and valley vented under truck
Just make the single catch can large enough and youll be fine
Old Nov 29, 2015 | 10:20 PM
  #428
Blown06's Avatar
8 Second Truck Club
If you can get the big lines off the valvecovers, skip the valley cover and potential trouble with it puking oil.
I run a -12 out of each valve cover to catch cans.
Old Nov 29, 2015 | 10:26 PM
  #429
GMCtrk's Avatar
They've got screw on fittings that go into the oil fill hole which are -10 for $35
I'm already getting annoyed with this thing..sick of spending more and more money.
Old Nov 29, 2015 | 11:44 PM
  #430
FFDP's Avatar
Well, you did wanna go fast though.
