Yet another turbo build...
Old Nov 15, 2015 | 10:05 AM
  #371
Choda's Avatar
Love this truck and build. Good job man
Old Nov 15, 2015 | 10:50 AM
  #372
GMCtrk's Avatar
Guys, 21 psi on a 6.0 should be around 900+ whp. I'm actually amazed that the injectors have gone this far. I'm still running stock fuel lines and filter and I don't think they're hurting me in any significant way. The walbro 450 pumps have the ability to push thru.
Old Nov 15, 2015 | 11:05 AM
  #373
George C....'s Avatar
Formerly ScreamingL
21 psi may only be 800 range wont know till you toss it on dyno
and yes the 3/8 feed lines are hurting ya
Old Nov 15, 2015 | 11:08 AM
  #374
smokeshow's Avatar
Mod with training wheels
That was my thought...also impressed those injectors are going as far as they have. What lambda value do you target?
Old Nov 15, 2015 | 11:18 AM
  #375
Vortec350ss's Avatar
Is it safe to assume you dont have a fuel pressure gauge?
Old Nov 15, 2015 | 11:30 AM
  #376
03chevytruck's Avatar
Glad to see it performing well!! I cant wait to see the track times!! I'm hoping to push 18-20ish to my 4.8 with your old s475. Great job!
Old Nov 15, 2015 | 11:41 AM
  #377
GMCtrk's Avatar
I do (electronic), which I log thru the EGR.
FP is good at WO.
Smoke, my target EQ ratio is 1.35. Thus, lambda of ~.74
I'm happy with my AFR in the 7.2-7.5:1 range.
Old Nov 15, 2015 | 11:45 AM
  #378
GMCtrk's Avatar
130 trap and 5k raceweight. That's on 17 psi from a smaller turbo with IATs double what I'm seeing now. The track is my dyno.
And regarding the stock fuel lines, where is your evidence they're hurting me?
Old Nov 15, 2015 | 11:54 AM
  #379
Formerly ScreamingL
Its been posted for years dating back as far as parish how stock lines became a issue around 700 but now youre on e85 and saying its fine
Duty cycle is also effected by line size
But with that logic my -12 feeding my pump is gonna be overkill
Old Nov 15, 2015 | 11:57 AM
  #380
GMCtrk's Avatar
George, use your brain a bit. Duty cycle is only affected by line size if there is a pressure drop from the pump to the rail. My FP gauge is showing appropriate pressure given 1:1 rise from 4 bar base. Therefore, stock 3/8 line isn't causing any significant restriction. Line size is only a problem when you have fuel pump(s) that cannot overcome the pressure drop inherent to the line. Whatever issue Parish had is irrelevant to me as he didn't have the 450 pumps at his disposal. They are extremely stout pumps.
