Yet another turbo build...
#372
Guys, 21 psi on a 6.0 should be around 900+ whp. I'm actually amazed that the injectors have gone this far. I'm still running stock fuel lines and filter and I don't think they're hurting me in any significant way. The walbro 450 pumps have the ability to push thru.
#374
That was my thought...also impressed those injectors are going as far as they have. What lambda value do you target?
#378
And regarding the stock fuel lines, where is your evidence they're hurting me?
#379
Duty cycle is also effected by line size
But with that logic my -12 feeding my pump is gonna be overkill
#380
George, use your brain a bit. Duty cycle is only affected by line size if there is a pressure drop from the pump to the rail. My FP gauge is showing appropriate pressure given 1:1 rise from 4 bar base. Therefore, stock 3/8 line isn't causing any significant restriction. Line size is only a problem when you have fuel pump(s) that cannot overcome the pressure drop inherent to the line. Whatever issue Parish had is irrelevant to me as he didn't have the 450 pumps at his disposal. They are extremely stout pumps.
