Yet another turbo build...
Old Jan 14, 2013 | 08:49 PM
  #91
GMCtrk's Avatar
Damn that sounds good. Hoping I get similar results.
Old Jan 16, 2013 | 04:39 PM
  #92
GMCtrk's Avatar
75 lbs worth of piping came in today
4" is serious stuff. It's crazy to think that I was considering 5 inch, but it cost $200 more. I just don't see it being worthwhile On this set up.
The muffler is only 15.5 inches long. So I really don't see it doing much in terms of sound reduction. But we'll see.
Anyways, this seems like a pretty nice kit for the price. It does cost $500 less than my old Corsa catback. Yeah it's not stainless steel And it doesn't come with nice band Clamps but is still a pretty good value at $287 shipped in my opinion.
Oh and I forgot to add, after some measurements I discovered that I won't even need the front most piece of pipe That connects the downpipe that comes with the kit. So conceivably somebody looking to do a similar set up in the future could just find the Duramax catback kit Instead of the turbo back kit. It seems to be about $40 price difference.
Old Jan 16, 2013 | 04:43 PM
  #93
oakley6575's Avatar
Are you going to weld the kit in?
Old Jan 16, 2013 | 05:12 PM
  #94
GMCtrk's Avatar
Nope. Everything should be slip fit, I'll just have to trim some of the pipes to proper length. The only thing I would do differently if I could weld would be to weld in a ball and socket joint at the down pipe connection.
Old Jan 16, 2013 | 05:18 PM
  #95
Atomic's Avatar
I have a gauge for that
flowmaster sells some universal ball and socket exhaust parts
Old Jan 18, 2013 | 09:11 PM
  #96
GMCtrk's Avatar
Got the MBRP exhaust on. It was all basically bolt on. I had to literally cut 1" off one of the pipes and that was it. The tailpipe needs to be trimmed but that's only because of my 6" rear drop. On a stock height truck it would be fine.
I didn't need the turbo back pipe or the 18" extension pipe. These kits clearly are designed for CCLB trucks and the rest are trim to fit.
Unfortunately, it's still loud as ****. Not S.O. approved. I may need to go to the 30" magnaflow.
Old Jan 20, 2013 | 06:47 PM
  #97
GMCtrk's Avatar
Took the truck out to do some non-boost tuning, mainly highway. Got on the highway and found myself tipping into boost just a couple psi but noticed blue smoke out my exhaust. That turbo whistle is just addicting. Forgot I was still running the stock PCV setup. I'm thinking that's why I had blue smoke out the exhaust, but it could also be the way I have my oil drain routed. I'm going to fix my PCV and then re-asses.
Here's what I'm doing for my PCV. It's a fully closed PCV system that works like stock but will positively evacuate the crankcase during boost.
I drilled/cut out my driver's side PCV valve so it's just a port now. And I'll be using an LS1 passenger valve cover that has 2 ports compared to mine which only has 1.
Top port goes to intake vacuum port. Bottom 2 ports connect to valve covers. And then a separate line will go from my air filter to the 2nd port on the passenger valve cover for vacuum while under boost.
Old Jan 20, 2013 | 07:22 PM
  #98
Where did you buy that and how much was it. I am only about a week away from needing one of these myself. PM me if it's a non site sponser. Thanks
Old Jan 20, 2013 | 08:14 PM
  #99
CrustyWeasel's Avatar
more info on exhaust i need the same thing
Old Jan 20, 2013 | 08:43 PM
  #100
GMCtrk's Avatar
i got it from Mightymouse on LS1tech. $135.
