Winter project(s)
Old Mar 27, 2013 | 11:01 PM
  #201
smokeshow's Avatar
Mod with training wheels
Got the segment swap from HP Tuners and the trans shifts perfect now. Was out testing the truck out and I pulled over to write a tune to it and it wouldn't stay running after trying to re-start it. Starts fine, then a split second later the idle starts chugging and it slowly dies. Any throttle input kills it instantly. Re-wrote the tune calibration 3 times, tried a write entire once....no change. Had to get towed back cause the bitch won't stay running. Didn't change anything about the idle, etc...just random **** in the tune and bam, its a vegetable. I have no idea what the deal it. Weird thing is, I have seen this on several other vehicles recently...trucks, cars, and not all with my laptop/cable. So wtf...
Old Mar 27, 2013 | 11:43 PM
  #202
Atomic's Avatar
I have a gauge for that
How do the logs look?
Old Mar 27, 2013 | 11:46 PM
  #203
smokeshow's Avatar
Fantastic, how else would they look?!
Old Mar 27, 2013 | 11:49 PM
  #204
oakley6575's Avatar
Glad you didn't chase your tail with that.
Does it just sputter like hell until it dies? Mine did this last time I drove my truck. Starts right up and will run for a sec and then starts to sputter horribly till it dies. I didn't know other people were having this issue.
Old Mar 28, 2013 | 12:02 AM
  #205
smokeshow's Avatar
I have seen quite a few do this recently. None so bad as this though, to just refuse to run entirely...
Old Mar 28, 2013 | 12:06 AM
  #206
oakley6575's Avatar
I'd be really interested in a vid cause it sounds like mine acted the exact same way. I had to come back up to school so I didn't get to dig into it. Have you seen any discussions over on HPT to suggest it might be from the software?
Old Mar 28, 2013 | 12:30 AM
  #207
smokeshow's Avatar
MVI_1921 - YouTube
I saw one guy on HPT forum saying he had a 2005 C6 do the same thing. It was cured by flashing the tune back to the stock OS with a Tech 2 and then writing his tune back into it.
Old Mar 28, 2013 | 12:36 AM
  #208
oakley6575's Avatar
Wow, yep that is the same as mine. I wonder what in the hell causes it. Mine would break up like that real bad until I gave it more than 50% throttle then it would clean up under moderate acceleration. Then right back to that bullshit while cruising. And then while coming to a stop light, or slowing down, it would die. Hopefully you find a fix right away man.
Did you already flash it back to stock?
Old Mar 28, 2013 | 12:44 AM
  #209
smokeshow's Avatar
I don't have a tech 2 to flash it with.
Old Mar 28, 2013 | 03:06 AM
  #210
smokeshow's Avatar
Just thought of something... Some PCMs are sensitive to the DTC settings you choose when disabling the MAF for SD. I believe I may have set mine so that its pissing off the PCM.. I will try changing that tomorrow, see how/if it runs lol.
