Usabodyguard's Project - Blwnlsx
Old Sep 28, 2009 | 11:21 AM
  #981
DrX's Avatar
DrX
The LS7 TB will usually work with or without cutting the pink wires, but will open more if they are cut. In the odd case, an LS7 TB will operate like a truck style TB and the pink wires must not be cut or REP mode will be triggered.
The old X-Link 1.0 units had a single long pink wire that has to be connected to a 5V reference source. Those units will not work with the truck style TB unless you add an external resistor.
Here is our ETC Troubleshooting document:
Old Sep 28, 2009 | 11:57 AM
  #982
zippy's Avatar
I forgot that the newer X-Link doesn't have the extra wire like that. One of my friends had this same problem recently and had a bad X-Link. Could be a programming issue, but not likely.
Old Sep 28, 2009 | 12:11 PM
  #983
Spoolin's Avatar
GFYS and STFU
My truck does the same thing FP wise at key on, I get about 60psi then after the pump shuts off it drops down to like 10-15 psi real quickly. My solution is either start the truck when the pump is on for the first three seconds or turn the key off and back on to prime it again and start the truck then! Or just keep cranking till the FP raises up and the truck starts cuz the fuel pump kicks in when your cranking! No biggie!!
Old Sep 28, 2009 | 01:00 PM
  #984
usabodyguard's Avatar
Blown 427 LSX
I am in REDUCED ENGINE POWER mode (rep) now, so my first inclination is to reconnect the wires together.
I recently had the entire AC system polished, lines - dryer - pump - bracket, I will double check those connections but I really doubt anything was cut.
Zippy when you get a chance give me a shout, I tried calling you earlier, it went to VM.
I really need to get this bitch started today, thanks for all of your help guys - anyone else have ideas on those codes maybe?
  #985
Holty's Avatar
Notorious BIG
Dave, do you have any more pics of your fuel system, especially under the hood, how you routed everything, etc?
Old Sep 28, 2009 | 01:01 PM
  #986
BlownChevy's Avatar
blownerator
25 Year Member
bet it is one of the connections where you extended your throttle actuator wires.
Old Sep 28, 2009 | 01:37 PM
  #987
Blown 427 LSX
I pulled the plug and made sure all of thee wires were Soldered together and are all wired correctly, when i reconnect the pink wires I would double check them again.
Josh - I have fuel pressure now, that isnt an issue anymore, but for fuel lines -
-10 main from fuel pump goes into a fuel filter then splits off at a Y block, two -8 lines feed the rails, out the front 2 -6 lines goto the FPR, a -8 return goes back into the surge tank... all of the fittings are tight without any leaks.
The only problem are the two codes
Old Sep 28, 2009 | 01:40 PM
  #988
BlownChevy's Avatar
blownerator
25 Year Member
and those codes are?
Old Sep 28, 2009 | 02:14 PM
  #989
Blown 427 LSX
theyre listed above, but here they are -
p0220
p2135
Old Sep 28, 2009 | 04:20 PM
  #990
BlownChevy's Avatar
blownerator
25 Year Member
p0220
p2135
Both being throttle position codes I would be spending most of my time verifying the wiring (again) and the x-link.
