Steve-o-08's Silverado Build Thread, Take Three.
Old Aug 22, 2017 | 08:36 PM
  #291
BigKID's Avatar
Sorry for the confusion, I'm looking for a 10" spring. I'm not sure an 8" will work on my coilover at current ride height.
Old Aug 22, 2017 | 08:50 PM
  #292
Atomic's Avatar
I have a gauge for that
Hyperco makes a 1300lb in 7in. How much shock compression travel do you have? Might could fit a 7 or 8" spring. What shocks do you have?
Old Aug 22, 2017 | 09:36 PM
  #293
BigKID's Avatar
Ridetech HQ 4.1 with ~1.5" compression and extension from ride height. The collar is currently about half way up the body so not sure I can move it up 2" for an 8" spring. Definitely cannot use a 7" spring.
Old Aug 23, 2017 | 12:04 AM
  #294
Atomic's Avatar
Well you could go to a shorter shock if you want to use a stiffer spring. You could use my 2wd brackets and have a stronger mount and take up some of that room at the same time. Would need different shocks to maintain your ride height though.
Old Aug 27, 2017 | 12:54 PM
  #295
Kamarokrs's Avatar
Registered User
Steve, awesome build. I was gonna sell my 99 2dr Tahoe but you have inspired me to go this direction. I do have a question...at one point you considered a splined sway bar and you posted a few links, why didn't you go that route?
Chris
Old Sep 3, 2017 | 11:37 PM
  #296
Steve-O-08's Avatar
Chris
Still may consider doing a splined bar. At the time I didn't realize I was so under-sprung in the front. I was relying too much on the sway bar to keep the truck from rolling over instead of upping spring rate to help support the truck. I have an idea for an adjustable rear bar that I might start working on later this year. Right now I'm going to see how the truck works out and see if I can dial it in some more at the next few events.
Old Sep 5, 2017 | 03:56 PM
  #297
The_W's Avatar
Were you able to grab any video clips on how it runs after you swapped the t56 in it?
Old Sep 6, 2017 | 10:37 AM
  #298
Steve-O-08's Avatar
I do have a quick clip of me driving it around. I'll have some in-cab and outside views at the next autocross event coming up week after next. Just been really busy with work and house stuff. I'll try to get it posted this week.
Old Nov 10, 2017 | 03:05 PM
  #299
Steve-O-08's Avatar
Figured I better update this thread. Had a few issued with the truck after the transmission swap. I was having a throttle issue where the truck would go into limp mode on a long second gear pull. To try and narrow down the issue I swapped the 90mm LS3 and X-Link out for a stock throttle body. This ended up not fixing the issue and kept me from running the truck at one of the autocross events I went to. After looking at the tune file for the 100th time I realized the problem was with the Calculated Airmass vs TPS vs RPM table and Part of the segment swap. Made some adjustments and the problem was fixed.
Then at the last NMCA event of the year I got a few runs out of the truck before I lost the clutch. At first I thought it was the throwout bearing locking up, but after towing it home and tearing it apart I found out the pilot bearing failed. Part of it hurt end the sleeve that the throwout bearing rides on and kept it from extending completely. Unfortunately with the pilot bearing out, the input shaft of the trans chewed up the inside of the pilot bearing and now there is a slight amount of play in the input shaft. Going to swap out the input shaft and pilot bearing for a bushing and get the truck back out and get it dialed in.
While the truck was dawn I also started my own Flex Fuel conversion. Which I had wanted to do for a while. After seeing a few companies' setups I realized I had almost all of the pieces leftover from other projects to build my own. Not bad for less than $100 in parts. Haven't messed with the tune part of it yet, but I will when I get the truck back up and running.
Overall it's a bummer that I wasn't able to get some solid events out of the truck this year but I have a lot planned for next year. A few f those plans including swapping a 6 speed into Claudia's truck along with some more power and potentially some new brake/suspension parts for both trucks. Stay tuned.
Old Nov 13, 2017 | 04:41 PM
  #300
The_W's Avatar
do you think if you had a cable throttle body it could have been avoided?
