Spoolin's attempt to Spool...
Old Feb 26, 2011 | 02:19 AM
  #401
BullyDogJason's Avatar
FormerVendor
thats a sick looking truck
Old Mar 10, 2011 | 04:33 AM
  #402
Spoolin's Avatar
GFYS and STFU
Welp...I got a job and am shipping out again!!
It's good cuz I need the $$ but it puts me in a bit of a bind with the truck. I have made a commitment to a competition that I'm participating in that I'll have it ready by May 27th. But I won't be getting home from work until May 23rd so it gives me 3 days to get it finished and running.
It's currently still at the exhaust shop, I gave them until April 18th (which is a day that I come home to LA for a day or so) to finish it up at which point I'm gonna tow it home.
This is what's left to be finished on the truck once I get it back...
-Wire E-fans up
-Mount external Tranny cooler and power steering cooler
-Run fuel tank vent into tail lights,
-Run crank case vents to the back of truck,
-Install overflow tank and run all coolant plumbing lines.
-Wire up 2nd Fuel pump
-Install Meth tank and nozzles.
-Wire up Wide-band sensor
-Install gas cap on my remote custom tank.
-Plug in the remainder of the wiring harness
-Re-install front fender and hood
-Fill with fluids and start the truck...
We'll see what happens!!
Old Mar 10, 2011 | 06:31 AM
  #403
stock48's Avatar
9 Second Truck Club
-Wire E-fans up
Damn thats cutting it close! Hope you have a good tuner hand
Everything is looking good! I wouldn't run the crank case vents to the back, I could see that costing you power. That engine didn't have any untill you got ahold of it...
Old Mar 10, 2011 | 09:01 AM
  #404
double047's Avatar
14 Second Truck Club
Coming out great man, looking forward to seeing it in person some day.
Old Mar 10, 2011 | 12:58 PM
  #405
Spoolin's Avatar
GFYS and STFU
You thinking just vents? My valve covers have bungs welded in them that kinda prevents that. I plan on running an electric vacuume pump eventually but can't really do that right now because of time constraints.
For sure buddy!!!
Old Mar 10, 2011 | 03:07 PM
  #406
stock48's Avatar
9 Second Truck Club
Just shove a piece of 5/8 or 3/4 hose over the an fitting, then put a push in breather in the other end. Thats how I do it.
Old Mar 10, 2011 | 05:50 PM
  #407
2004SSS's Avatar
mine is ran similar , two -12 hose's to a moroso catch can with breather.
if you need any help man give me a text/ring . if you need it picked up or dropped off ill do what i can to get this thing to the throwdown. good luck at sea and stay safe man !!!
Old Mar 11, 2011 | 08:25 AM
  #408
Spoolin's Avatar
GFYS and STFU
Thanks bud! I might take you up on your trailer offer in April when I come home for a few days, might need to tow it further than my AAA 100 mile range allows for!!
Can't wait to see your truck pounding the pavement!!
Old Mar 11, 2011 | 12:11 PM
  #409
2004SSS's Avatar
yeah anytime you need it man . as long as im not using it . im not sure if i will trailer to throwdown or drive it . may drive it and follow with the trailer just in case. getting a 2wd on the trailer is alot different than my awd . pats truck almost shot a ramp out . the winch is actually helpful even if the truck is running and driveable.
if not i have a 200 mile tow with AAA .
Old Mar 14, 2011 | 09:21 AM
  #410
bigboy576103's Avatar
Thatsss soooo seeexxxyyyyy
