Spoolin's attempt to Spool...
Old Jan 20, 2011 | 11:22 AM
  #251
SincalT/A's Avatar
Use a heat gun on the connectors.The glue will soften enough to pull them also reheat when you plug them back in.Its like GM's stupid funny joke on the world....Only thing is no one laughs when they break well it least not me anyway.
Old Jan 20, 2011 | 12:02 PM
  #252
SincalT/A's Avatar
LoL! I see this was already suggested.
Btw..The build is coming together nice&clean.Hopefully ill be able to see it in person.
Old Jan 20, 2011 | 12:19 PM
  #253
Spoolin's Avatar
GFYS and STFU
Originally Posted by jared91
...where abouts are you located man?
The ****-hole that is Los Angeles. Actually it's not that bad, it's just I hate the amount of people that live here, I'd be perfectly happy living anywhere in the Midwest.
Originally Posted by Atomic
Why are you up so early?
Up so late more like. For no apparent good reason I've been going to bed really late lately. I gotta get back on a better schedule.
Originally Posted by Wilde Racing
Zip ties? you are on the two-three fuel line support program??? ...The connectors are glued, most "normal" people unbolt the thing from the trans..
You don't like all my zip ties!! If you can recommend a better way I'm all ears!!
btw...I completely forgot that the stupid module unbolts from the tranny, hence why I did it that way, I don't remember us doing it that way but thinking back now, we obviously must have!
(Amnesia's a bitch )
Originally Posted by charcold-bowtie
My old tranny builder said they use some sort of silicone or something on those plugs, and they usually end up stuck. Mine has the single plug up there instead, and ive never had anytrouble. I cant believe you cut it tho!
I wanna claim temporary bout of idiocy was responsible for that...but I'd be lying if I used the word temporary!
...The build is coming together nice&clean.Hopefully ill be able to see it in person.
Thanks bud! Anytime you stop by SoCal just give a holla!
Old Jan 20, 2011 | 12:27 PM
  #254
camochevy21's Avatar
That is very clean! Looks awesome, coming together very nicely.
Old Jan 20, 2011 | 01:43 PM
  #255
Spoolin's Avatar
GFYS and STFU
Thanks man!!
Old Jan 20, 2011 | 01:46 PM
  #256
Spoolin's Avatar
GFYS and STFU
So I have a new question, surprising I know!!
I'm looking for an oil cooler block that has an additional outlet port that I can use to run oil supply to my turbo while retaining the engine oil cooler lines.
You guys think this will work alright??
http://www.lingenfelter.com/mm5/merc...gory_Code=C186
If so, Looks like I'll be needing to run new coolant lines from the block to the radiator, what fittings am I gonna need that plug into the radiator? This is what those fittings look like on the other end of the coolant lines that fit into the radiator. I'd love to be able to re-use those lines but doubt that would be possible. I know those fittings are two part fitting too, which would be easier to make it adapt to the radiator, the threaded ones or the clip on ones?
Old Jan 20, 2011 | 02:10 PM
  #257
jared91's Avatar
Originally Posted by mhotrodscooter
Them transmission plugs can be a pain in the ***. Seems like they superglued them in. I've fought with them sob for hours, and ended up just removing the whole thing like you did.
sorry for the thread jack, but since im doin a trans swap, will i have to take that off my old trans and put it on my new one or what? ill pm you about it
Old Jan 20, 2011 | 05:18 PM
  #258
JoeyGC5's Avatar
Thats the block on my HD truck that I used for my turbo feed, just drill into and tap for an fitting. I used the Lingenfelter adaptor on a buddies f-body and it worked out well.
Old Jan 20, 2011 | 06:54 PM
  #259
vicalma03's Avatar
Why can't you use the factory oil cooler lines/block?? That's what I planned on using as a feed.
Old Jan 20, 2011 | 07:57 PM
  #260
charcold-bowtie's Avatar
I would just cut those hard lines, use them to get into the radiator, and go to your SS hose, thats what I did.
Or figure out what thread they are at a harware store, and order the proper AN fitting to get out of the radiator
