Slow and getting slower
Old Jun 9, 2012 | 11:59 PM
  #951
Atomic's Avatar
I have a gauge for that
I didnt know fastenal sold clevis bolts....or are you doing it differently?
The shock brackets I got from ebay, the seller was variations by valentino
Old Jun 10, 2012 | 08:02 AM
  #952
03sierraslt's Avatar
No, not the clevis bolts. I was refering to the new lower shock bolts etc. I am doing mine the same way with the clevis. Just need to double check my measurements as I forget if I new 10" or 11" straps
Old Jun 11, 2012 | 07:33 AM
  #953
Spoolin's Avatar
GFYS and STFU
Richard, at what fuel pressure are those injectors rated at, 48lbs no? Driver box or low impedance?
Old Jun 11, 2012 | 07:47 AM
  #954
Low Impedance requires a Driver Box.
Old Jun 11, 2012 | 08:14 AM
  #955
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You can post links to the stuff as long as a sponsor doesn't sell it.
Old Jun 11, 2012 | 08:52 AM
  #956
Atomic's Avatar
Injectors were tested at 43.5psi and flowed 114.6lb/hr so at 58 psi should be 132lb/hr
Old Jun 12, 2012 | 12:28 PM
  #957
Spoolin's Avatar
GFYS and STFU
You know what I meant.
Sweet, should keep you busy for a little while.
Old Jun 12, 2012 | 01:36 PM
  #958
idahoblkss's Avatar
I didnt get my 6.33 but I did get a 6.5x@103 with a 1.4x 60', https://www.performancetrucks.net/fo...2-73-a-502339/
...and I finally put this on...
lmao!!! tell me they let you keep it on at the track!!??
Old Jun 12, 2012 | 02:38 PM
  #959
nonnieselman's Avatar
Have you got a boat prop in the hitch yet?
I saw one at bass pro the other day and thought about it.
Old Jun 12, 2012 | 02:58 PM
  #960
Atomic's Avatar
I thought I needed 9s for that first?
I did get my new 127lb injectors installed, and after figuring out one of the wires was loose in the connector causing the injector to malfunction everything is good to go.
I havent been back to the track since putting my ladder rack on, so im not sure what they will say.
