Slow and getting slower
Old Feb 20, 2013 | 10:04 AM
  #1451
chevyboy.520's Avatar
Can you tell a difference in oil temp by running that oil cooler ?
Old Feb 20, 2013 | 10:12 AM
  #1452
Atomic's Avatar
I have a gauge for that
Usually couple hours each way, being 4wd complicates it somewhat, and Ill have to take off part of my exhaust (being 5" its in the way).
Huge difference in temps with the cooler, at least 50-60degrees.
Old Feb 20, 2013 | 10:14 AM
  #1453
What size is the cooler?
Old Feb 20, 2013 | 10:15 AM
  #1454
Do you have a link to that block you got off evay
Old Feb 20, 2013 | 10:25 AM
  #1455
Atomic's Avatar
Just a generic B&M cooler, nothing special, 6x10 maybe. No but if you search "ls oil cooler block" or something similar you should be able to find it.
Old Feb 20, 2013 | 11:08 AM
  #1456
WyoDudeC5's Avatar
Maybe someone mentioned this, but, is the weight you listed in your specs correct at over 6K lbs? Dang, I would never have believed that. I happened to have a brochure for the 2013 GMC 1500 and sure enough, the weight is listed at 6400-6800 lbs. If you can make this thing perform at that weight, you are a magician....good luck.
Old Feb 20, 2013 | 11:14 AM
  #1457
Atomic's Avatar
My last truck was, 04 silvy 4wd, lifted, 14b, big tires, etc. Weighed right at 6400 with me in it.
I actually had this one on the scales last weekend, without me it weighed right at 4750 with half a tank; about 950 on the back tires and 1400 on the fronts. Im about 250.
Old Feb 20, 2013 | 11:35 AM
  #1458
Phantom's Avatar
11 Second Club
#3 plug wire doens't look like its on all the way
Old Feb 20, 2013 | 04:50 PM
  #1459
Atomic's Avatar
The wires are all custom, and the metal clamp sits farther down in the msd ends than the summit ones on 5 and 7, but I assure you its on there.
Old Feb 20, 2013 | 04:55 PM
  #1460
oakley6575's Avatar
I found that oil block on ebay last night. Looks like a nice piece. Any pics of the converter? I bet it is a nice piece.
