Project Kermit
Old Aug 19, 2009 | 05:26 AM
  #561
00Silv4.8's Avatar
dam man, good work! as for the trans thats weird.. Look up tolerances. I had to look em up for my 80e being pulled about 3/8" I belive it was? and it can have like up to 1 1/16" I wanna say? could be wrong Ill try and find the link...
heres one... little more than half way down it has maximum tolerance..
http://www.partshp.com/ConverterInstructions.htm
Old Aug 19, 2009 | 05:46 AM
  #562
Spoolin's Avatar
GFYS and STFU
Originally Posted by usabodyguard
It is a level sensor... and I am not using mine anymore (since I have a custom aluminum tank and no bung for it)... mine isnt a DD, so I can add it to my checklist it in pre-flight
Are you not using your whole tank or just not the sensor? Can I grab the sensor from you? I guess we'll figure it out manana! I might have to go to the dealership and Hawaii Racing tomorrow as well so it will be a full day and I gotta be back in downtown by 3:30pm too. I'm borrowing scotty's car at 9:30 and gonna shoot straight to Hawaii then over to you, maybe I can lighten your load by taking that level sensor from you!!
Very cool!!
I'm gonna talk to chuck/vince or Andy tomorrow as well as Dave at Yank and just verify with them on what their opinions are on it then I will unbolt the converter and push it back as far as I can...it's possible that the converter slipped out one "click" when the tranny fell on my face and I didn't notice it!!
No harm in unbolting the converter and seeing how far back into the trans she'll go without damaging the pump and re-measuring the clearances. The whole converter mounting issue is the only thing about this build that has me freaked out, one simple little mistake and there goes $1000 in rebuilding the damn pump!
Gotta get it right the first time!
...NOW WHO'S WITH ME!!!
Old Aug 19, 2009 | 05:49 AM
  #563
Spoolin's Avatar
GFYS and STFU
Originally Posted by 2005 Silverado
When i did my V8 swap my i had the same connector issue with the overflow.
I had it tuned so that it would not turn that code or warning light on until it got to so hot...basically if figured, i have a gauge, i know if i have a leak ill smell it, and if the v6 didn't have it, the v8 dont, so take those $.02 for what they are worth. I just have a floating connector
Dustin
You lost me dustin, you talking about the level sensor? I have the harness plug, just no sensor in the bottom of the overflow tank, think it fell out. I could dissable it like your suggesting but I figure since I have the harness capabilities, might as well use it!
I'm gonna have enough floating connecters as it is anyways! I think I counted 12 at last count!
Old Aug 19, 2009 | 11:40 AM
  #564
whitegmc2003's Avatar
i might have missed it but what motor do you have?
Old Aug 19, 2009 | 12:21 PM
  #565
usabodyguard's Avatar
Blown 427 LSX
he has a forged 370...
Old Aug 19, 2009 | 12:51 PM
  #566
thunderwagen's Avatar
Originally Posted by Spoolin
You two have CURSED ME!!!! ...
When your motor leaks oil out of every hole that it can, then you can blame me for the curse!
Old Aug 19, 2009 | 01:29 PM
  #567
O
Old Aug 19, 2009 | 04:13 PM
  #568
1FastBrick's Avatar
Custm2500's Rude Friend
Its not just about using the sensor and wether it works or not but you have to plug the hole up as well other wise you will have a leak when you go to fill it up!!!
Old Aug 19, 2009 | 04:18 PM
  #569
1FastBrick's Avatar
Um I think your Up Creek with out a padle or any Biohazard gear....
I also hear crickets chirping in the backround...
Old Aug 19, 2009 | 07:42 PM
  #570
Stoichiometric's Avatar
You won't have the low coolant sensor on that overflow tank, it comes without it from the factory. Turn off the light in the calibration.
