Project Kermit
Old Aug 19, 2009 | 07:42 PM
  #571
Stoichiometric's Avatar
You won't have the low coolant sensor on that overflow tank, it comes without it from the factory. Turn off the light in the calibration.
Old Aug 19, 2009 | 11:48 PM
  #572
2005 Silverado's Avatar
SPAM HUNTER
Originally Posted by Spoolin
You lost me dustin, you talking about the level sensor? I have the harness plug, just no sensor in the bottom of the overflow tank, think it fell out. I could dissable it like your suggesting but I figure since I have the harness capabilities, might as well use it!
I'm gonna have enough floating connecters as it is anyways! I think I counted 12 at last count!
I have 2...in the engine bay and like 3 by the transmission.
Dustin
Old Aug 20, 2009 | 01:32 AM
  #573
Spoolin's Avatar
GFYS and STFU
Than where did that harness come from? It the truck didn't come with a level sensor why does the harness have one?? Well anyways, it's a moot point right now because I bought Dave's old Overflow tank and it has the sensor so I'm gonna swap the tanks so now I have a Overflow tank with a level sensor!!!
Sorry I missed your call, was at a birthday party. The whole time I was thinking I wanna go home and finish up the truck!
Old Aug 20, 2009 | 11:03 PM
  #574
SLOXCAB's Avatar
progress??
Old Aug 20, 2009 | 11:15 PM
  #575
Spoolin's Avatar
GFYS and STFU
Went shopping yesterday!!
Went to Harbor Freight for the first time... That place is cool as ****!!
Kinda wish I woulda gone there before I bought most of my tools, coulda easily save lots and lots of money but...oh well! Also bought some stuff off of Dave that he isn't gonna be using anymore, such as his coolant tank, Air box, alternator and some other random stuff.
So I spent a little bit of the morning installing this big clunky metal thing...
I have a Sears work bench which is not much more than MDF I'm afraid so I went to Home Depot and got a few things to help secure it better...
Along with the nuts and bolts I bought some 3/8th inch thick steel washers and figured I would need some rubber mounts so that if the Vice does move around a little bit, it wouldn't start scoring and digging into the bench.
I found that these door stoppers/furniture pads to be exactly the perfect size! So I drilled a hole in the middle so the bolt can go through...
Also bought some steel washers for underneath, and you can see the holes I drilled in the bench...
Anyways, I forgot to take a picture of the finished product but will try and remember later. I did get my bellhousing cover/inspection cover finally!!
As soon as I saw it though I knew immediately that it isn't gonna fit, I don't have that much room between the flex plate and the engine for that lip to fit between. Think I might have to hack up that cover to make it fit!!
Also here is the gap I was talking about between the converter and the oil pump...
Talked to Chuck @ FLT who said it sounded like a big gap when I explained it to him but suggested I talk to Dave @ Yank. So I gave him a call and he said that it looks big when compared to a stock converter because their housings are not as tall or wide if you will. So to compensate and make sure that the shafts stick in far enough they have a longer converter shaft and it looks like it's not installed all the way but in actuality it is. He suggested I disconnect the converter and push it down flush against the oil pump again just to make sure it is in fact all the way in and bolt it up again, so I will do that tomorrow if I can.
I also started on the fuel system, pics on that when I finish it though!
Old Aug 20, 2009 | 11:28 PM
  #576
1FastBrick's Avatar
Custm2500's Rude Friend
were did you get the converter cover from??? Do you still need that dip stick???
Old Aug 21, 2009 | 02:12 AM
  #577
Spoolin's Avatar
GFYS and STFU
Company called PATC. Ordered it online, cost $75 I think. The cover has me worried about that flexplate again!!
And yes I do still need the dip stick...
Old Aug 21, 2009 | 12:00 PM
  #578
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
well thats good news atleast you wont have to yank the tranny again thats good to no info as well from yank as far as the shaft being longer then the stock 4l80 converter
Old Aug 21, 2009 | 04:11 PM
  #579
1FastBrick's Avatar
You just want to see me again You big homo... Thats what the poke's all about isnt it....
Old Aug 21, 2009 | 05:59 PM
  #580
Spoolin's Avatar
GFYS and STFU
I got an early start today and thought I was gonna have the whole day to finish the truck up but apparently it wasn't meant to be, however I did get a few things accomplished which was good.
Here's the pic of the Vice...
Now I gotta secure the work bench to the floor because the whole bench starts to move when I out pressure on the vice!!
I got most of the fuel system figured out and done. I had to tear about 30% of it apart again and redo it because of fitment and clearance issues which ate up a good portion of my time but that's life!
This is what I started with...
And this is where I am at the moment + a few things not pictured...
I got these vice clamps that make rigging these fuel lines really easy...compared to how hard it would be without them!!
Only thing that is holding me back from finishing the fuel system at the moment is I need to fab a bracket to hold the FPR up against the firewall, after that I can hook up the remainder of the wiring harness, bolt on the exhaust and the intake, fill her with fluid, flash in a tune and go vroom vroom.
Speaking of exhaust, I noticed I had a third bung in my headers...
what's the extra one for? I guess I'll got get a plug for it. I have two O2 sensors that will plug in to each header but other than that I don't know of or have anything else to screw into the third bung.
