Project Kermit
Old Aug 8, 2009 | 02:30 AM
  #441
Spoolin's Avatar
GFYS and STFU
What else did you break??? What else should I bring to bail you out...
You got some spare bolts??
Originally Posted by Wilde Racing
HMMM, Looks like there is no room between the sensor and the housing for oil. I wonder how well that works... Or is it the new "block temp" sensor????
Your just jealous that at WOT my oil temp sensor pegged itself all the time!! Who doesn't need a gauge that tells you your engine is melting everytime you go past 1/2 throttle!
Well I'm not going back to his shop anymore, I have one of my own now!!
BTW. I didnt strip you pan bolts... But I bet the mr overtighting king of the world had nothing to do with it.... did he... lol
Who meeeeeee????? Actually if anybody did it, it sure as hell it was me but I must of done it at your place because I was pretty careful today. Those days of breaking bolts are over!!! Speaking of which, is this a good time to mention that when I was assembling my brakes a couple weeks ago I broke 5 grade 10.9 ARP bolts because I thought they said to tighten them to 150ft/lbs and not in actuality 150 in/lbs...
Nahhhh I'll keep that story for another time!!
Old Aug 8, 2009 | 04:20 AM
  #442
usabodyguard's Avatar
Blown 427 LSX
Originally Posted by Spoolin
Speaking of which, is this a good time to mention that when I was assembling my brakes I broke 5 grade 10.9 ARP bolts because I thought they said to tighten them to 150ft/lbs and not in actuality 150 in/lbs
duuuuuude! it took 5 bolts to figure this out lol...
My TW doesnt even go that high...
(i guess its a good thing, i'd be snapping off bolts left and right lol)
Old Aug 8, 2009 | 10:27 AM
  #443
Stoichiometric's Avatar
Pulled it off and re'used the gasket, hope it's the right one...
You need a gasket that has two individual holes for the oil cooler, its different than the one you have.
Old Aug 8, 2009 | 11:11 AM
  #444
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
Don't think you guys are getting away that easily though!! I still have a few questions I need some help with...
Along with the crank sensor clip that came with the wiring harness that comes around the oil pan came another clip that I don't know where it goes. There are two ground wires for the starter...haven't figured out which one goes where yet but I'm sure once I look at it I'll figure it out, but not sure where the clip goes...
Any suggestions?
ill put money on that the plug goes to the oil pan its a low oil light switch there should be a plug right under neath the starter as far as the other two the small one goes on the starter solenoid and so doesnt the big one look at the starter its self explains were the two goes ooh BTW your going to have to take the starter back out to get those two wires on
Old Aug 8, 2009 | 01:04 PM
  #445
Spoolin's Avatar
GFYS and STFU
I don't know how much more abuse that bolt hole can take before she's completely stripped out!
I knew I was gonna have to pull that starter back off to do it but was excited to get the fugger on!! Ok so I'll take a look at the back and see about connecting both of those up. I'll look around the (engine?) oil pan for a small clip to go to.
Old Aug 8, 2009 | 01:21 PM
  #446
thunderwagen's Avatar
Yep you have the wrong one. Like stated above two holes. I have one in the shop if you want to swing by and pick it up!
Old Aug 8, 2009 | 01:29 PM
  #447
SincalT/A's Avatar
Damn no offense but is like handycap wrenching thread....Wish I could watch/help you out but too far for me.Get a few beers in you then really be entertained.Hopefully see you at the meet.
Props anyways I wish I was wrenching on my pile.
Old Aug 8, 2009 | 01:47 PM
  #448
Spoolin's Avatar
GFYS and STFU
Ummm yeah let me swing by!!! Actually on your way home from work just stop by my place!
Sheeesshhhh!!! A guy can't break a few things here and there without being called a cripple?
Old Aug 8, 2009 | 02:07 PM
  #449
SincalT/A's Avatar
Naw man jfwy!I have been there done that too.Every time I wrench I learn all over again.
Old Aug 8, 2009 | 04:23 PM
  #450
I would drop it by but your hot neighbors would probably fall in love, and I'm not into the long distance thing.... So I'm gonna have to pass. Sorry bro.
Feel free to keep breaking stuff though. It makes e feel better about all the retarded stuff that has happened in my build.
