Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 19, 2006 | 09:10 PM
  #811
moregrip's Avatar
what a rush!
Originally Posted by wkdivr
I'm envious!!!
your a 1/2 can of VHT and a 1/4 roll of 3m tape away from having the same thing
Old Dec 19, 2006 | 09:37 PM
  #812
kbracing96's Avatar
Don't forget about the 5 hours of masking and taping and 30 seconds of spraying
Old Dec 19, 2006 | 09:40 PM
  #813
the original plan was having the 8" damper for the 112
yes I considered the ATI but it was a few dollars more than the Innovative. I don't know if ATI has a truck balancer available yet (probably so at this point)
I sent a stock GM damper in to Innovative for my current 8"/8rib setup, so I know for sure they have what they need to make a truck balancer in any configuration you'd like.
Innovative quoted 2 weeks for stock dia and had the 8" in stock,ATI could ship stock dia same day.My 3.3 won't need to spin nearly as high as your setup,so I went with the ATI complete set.
Old Dec 19, 2006 | 10:41 PM
  #814
moregrip's Avatar
what a rush!
very nice, that will be a sweet setup
Old Dec 19, 2006 | 11:24 PM
  #815
203Cree's Avatar
Lookin good Grippy. Just read thru the thread, you're doing things the Military way. All these guys that are laughing at your methods don't realize how **** we get with parts and whatnot in the service. The bagging and tagging, as you know, is standard fair. I do exactly the same when ever I tear something apart.
Looking forward to seeing it finished.
I had one thing to add about the post below.
however 3M makes different grades for different jobs, white would be better for aluminum IMO
http://products3.3m.com/catalog/us/e...er/output_html
You're mostly right about the white being better for aluminum. However, it's going to depend on what you're doing. If you're just cleaning a raw surface, or taking off light build up, they will work fine. If there's any type of paint or heavy carbon buildup on there however, you do have to step it up to the yellow discs. The white one's pretty much come apart, and then you have a FOD issue. I usually work it down to an acceptable level with the yellow then do the finish work with the white. That's all the white one's were really meant for anyway.
Old Dec 19, 2006 | 11:27 PM
  #816
moregrip's Avatar
what a rush!
thanks bro! excellent info on the discs
Old Dec 19, 2006 | 11:47 PM
  #817
Have you found a good place to buy 8rib belts yet?
Old Dec 19, 2006 | 11:51 PM
  #818
moregrip's Avatar
what a rush!
yeah, Napa, they carry them all, and the kicker is, they're cheaper than the 6 rib belts
Old Dec 20, 2006 | 01:04 AM
  #819
14 Second Truck Club
Everything looks awesome man! What are your predictions for rwhp/rwtq?
Old Dec 20, 2006 | 09:07 AM
  #820
zippy's Avatar
With your truck now having the 8" balancer, what blower pulley can you go to without overspinning the blower? What are you going to be shifting at?
