Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Dec 19, 2006 | 06:02 PM
  #801
moregrip's Avatar
what a rush!
Originally Posted by Bill Reid
Yep, will probably be collecting parts over the next couple months and then send the short block out to get built. I should have the block after x-mas. Think I'm going to do an LS6 based 346 or 382. The block will be coming with forged pistons for a 4" stroke crank. We'll see... you know how things are fluid until the last moment. One thing is for certain... I'm going to have to build a tranny. Been thinking about trying to do it myself...
The pics are great on your project... keep em coming
Bill
good deal, a 382 would rip!
Old Dec 19, 2006 | 06:03 PM
  #802
moregrip's Avatar
what a rush!
Originally Posted by 1SlowHoe
I can hear the engine block singing "I fell pretty,.. oh so pretty"
yeah, that VHT brake caliper paint works pretty damn good, who'd-a-thunk
Old Dec 19, 2006 | 06:08 PM
  #803
moregrip's Avatar
what a rush!
only thing that showed up UPS today is this Kent-Moore LS1/LS6/LQ4/LQ9 yada yada crank holding tool:
Old Dec 19, 2006 | 07:02 PM
  #804
Bill Reid's Avatar
... highly recommend that flywheel lock for installing/removing harmonic balancers...
Bill
Old Dec 19, 2006 | 07:39 PM
  #805
KySilverado's Avatar
I would have loved to have the crank holding tool on more than one occasion.
Old Dec 19, 2006 | 08:05 PM
  #806
moregrip's Avatar
what a rush!
this is excellent stuff for providing a smooth action under high pressure
keyway installed:
balancer on:
installed keyway shot:
I wasn't sure about how to install the new damper so I just followed Innovatives instructions which was to apply red loctite liberally around the crank snout/damper ID to prevent the two metals from direct contact, I did use anti-sieze on the keyway as well
Old Dec 19, 2006 | 08:16 PM
  #807
03lowriderss's Avatar
maybe a dumb question but is the whole point of the 8 rib pulley setup to try to eliminate belt slip on your supercharged application?
Old Dec 19, 2006 | 08:22 PM
  #808
moregrip's Avatar
what a rush!
not really to eliminate it because I never really had any with the MP112; more like preventative measures with the 122HH setup, if it ends up being overkill................I can live with that
Old Dec 19, 2006 | 08:51 PM
  #809
Did you consider the ATI damper at 7.5" with the MP122HH or did you go with the 8"Innovators damper,planning to go with the MP112?
Old Dec 19, 2006 | 09:08 PM
  #810
moregrip's Avatar
what a rush!
the original plan was having the 8" damper for the 112
yes I considered the ATI but it was a few dollars more than the Innovative. I don't know if ATI has a truck balancer available yet (probably so at this point)
I sent a stock GM damper in to Innovative for my current 8"/8rib setup, so I know for sure they have what they need to make a truck balancer in any configuration you'd like.
