Project 50 Shades LSXAP Shoptruck
Old Sep 6, 2015 | 11:43 PM
  #191
George C....'s Avatar
Formerly ScreamingL
Originally Posted by GMCtrk
What gives more hit, more or less preload? And when is more hit indicated with drag radial?
Top hole no preload with small air gap on bar supposed to be hardest hitting
Lower bar will soften hit
Caltrac manual states this with more detail
Old Sep 6, 2015 | 11:45 PM
  #192
GMCtrk's Avatar
I never got a caltrac manual with mine.
Also the yb thread states that more preload is a harder hit
Old Sep 6, 2015 | 11:50 PM
  #193
smokeshow's Avatar
Mod with training wheels
Well actually Corey added the 'nonsense', but realistically, it was just him adding some comedy to your already comical failure. A theory is only acceptable if you can demonstrate its validity with reason or an experiment. I'm not entirely sure what watching a go-pro video would prove beyond the anecdotal. Regardless, what I said still stands true; a shock absorber will dampen system response time no matter if its in compression or tension. This is the simple physical nature of a damper. Maybe you'd care to explain to the viewers what the geometry has to do with it...because this topic certainly has nothing to do with the direction in which the damper is displaced.
Old Sep 6, 2015 | 11:51 PM
  #194
Formerly ScreamingL
Visit caltrac site the manual is there
Old Sep 6, 2015 | 11:52 PM
  #195
GMCtrk's Avatar
When is more hit indicated
Old Sep 6, 2015 | 11:55 PM
  #196
Formerly ScreamingL
When a shock is only stiffening compression and not extension like most singles do then youll have a variance with shocks facing different directions
Factory does this on some trucks to help but thats for stock form, now in racing standing them up allows rhem to work the same and allow for better control over axle
Old Sep 6, 2015 | 11:58 PM
  #197
smokeshow's Avatar
Yes. Because of the geometry. Not the damper. The devil is in the details, as they say.
Old Sep 7, 2015 | 12:45 AM
  #198
BlackGMC's Avatar
Resident Retard
I was just trying to be one of the cool people who read something somewhere and references it.
Old Sep 7, 2015 | 10:25 AM
  #199
lsxperformance's Avatar
The only way to truly change ic is with the front spring eye either being lowered or raised. The rear eye may effect it but only really at neutral since everything will move and change when the spring arches and changes. The shocks are there to more finely control the movements that are going on. So you can have more control over the movement letting the chassis. I'm goin to pull the front end apart and check spring rates. I may switch to a softer longer spring that has more stored energy and look into a double adjustable shock. I'm seriously considering ladder baring the truck and moving weight around. So I can get better control of it and putting a bigger wheel and tire under it and just leave it parked till I'm done lol
Old Sep 9, 2015 | 11:48 PM
  #200
GMCtrk's Avatar
question was not answered, does this truck still have stock shock mount locations?
