Project 50 Shades LSXAP Shoptruck
Old Aug 18, 2015 | 11:14 AM
  #91
shootermwc's Avatar
With the speed density tune, are they completely doing away with the MAF? Because I've been trying to figure out what to do there with the 04 computer I've got trying to tune with boost. I havent dug into it very much, as I don't have the brain for HP Tuners, so I leave it to the pros.
Old Aug 18, 2015 | 11:16 AM
  #92
Vortec350ss's Avatar
Yea speed density removes the MAF
Old Aug 18, 2015 | 02:00 PM
  #93
shootermwc's Avatar
thanks vortec, I thought so
Old Aug 18, 2015 | 08:23 PM
  #94
Funkster's Avatar
12 Second Club
Dig the thread man, hopefully the mounts treat you well.
Old Aug 18, 2015 | 09:43 PM
  #95
lsxperformance's Avatar
You don't have to go speed density, I just decided to do it on mine because because it will be anyhow no big deal.. Talk to your tuner and see what they would rather do on your setup..
Old Aug 18, 2015 | 09:46 PM
  #96
Yep thanks again! I hope your deal worked out!
Old Aug 18, 2015 | 10:08 PM
  #97
I got the suspension straitened out today.. The shims I originally installed to set pinion angle were throwing off thrust angle so I had to do something else I ended up. Getting some 4* shims from speedway here locally. I stacked them and welded them together.. Then I got a 9/16 bolt and trimmed it to fit so the rear end had something to center it. It actually worked like a charm and got the thrust angle straitened out. And I feel more comfortable launching now it has somthing to hold the rearend instead of u bolts and hopes and dreams.. Then I'm going to recharge the ac, and hopefully tuned by the end of the week. Also put some preload in the rear with the assassin bars it's finally coming together.
Old Aug 18, 2015 | 10:44 PM
  #98
BlackGMC's Avatar
Resident Retard
Nice!
Old Aug 19, 2015 | 03:16 PM
  #99
Got the alignment figured out then took on a test drive and got on it once which was interesting... Bitch moves out!! Even n/a anyhow went into reduced engine power and so that was a buzz kill.. Went and back probed the connectors and found the throttle body to be bad.. tps1, and tps2 weren't the same and was making it hunt for idle, surge and do all kinds of weird stuff. Kinda sucks because that throttle body was ported.. So, another kick in the *****!!
#winning
Old Aug 19, 2015 | 03:31 PM
  #100
jesus man... keep your head up. Youre making progress.
