Preston129/BlkSlvrdo129 Build thread - TVS1900, EPS cam and more
#82
Depends who you listen to. I've read a lot of info from guys claiming the Cobalt SS with the 2.0L LSJ engine had a 2.5 bar MAP, but that it was a TMAP sensor, meaning both manifold pressure and IAT were tested from the same sensor. Like all other S/C GM engines, it has 3 MAP sensors; two of which I'm assuming are 1-bar while the final one was either the TMAP 2.5 like some people claim or just a 2 bar MAP. Here's a thread on Tech where someone claims to have a response from Delphi confirming the cobalt MAP was indeed just 2 bar.
For anyone interested, the 2 bar Delphi MAP p/n is: 12615136*
*The p/n mentioned within the link I posted is superseded by the above p/n.
#83
Got a couple more things in the mail:
Aeroforce scan gauge
First box, the gauge itself:
The white gauge face and stainless bezel ship with the kit, I wanted the the one that says "SS" just to keep a factory look to the gauge:
Cable that connects to the OBD-II port as well as an Add-a-Circuit for the wideband:
Back of the gauge, one digital input and two analog:
Contents of the second box, the wideband O2 sensor:
Bosch 02 sensor itself:
And the second item, a shorty billet antenna from a member on gmfs, jrluz14, who's a stand-up guy to deal with and has some cool designs for short antennas.
5"x3/8" with a pointed tip. Got it sandblasted so that I can either paint or PC it black:
#86
Got the Katech Delphi to Bosch MAP adapter harness yesterday.
Delphi connector:
Bosch connector:
Going to order a few more things today I think, exchange rate's pretty good.
Delphi connector:
Bosch connector:
#87
Re-routed the wiring for the driver side HID ballast to get the area in the aux battery tray clear.
Here's how I had it before:
And after:
And here's why I needed the extra space:
2 gallon composite water tank from Trick; really nicely made piece:
I had -12 fittings installed instead of the -10 that usually come with the tank:
Large mouth opening allows frozen water bottles to fit inside the tank on race day:
Bracket that attaches to the aux battery tray:
And after:
