Preston129/BlkSlvrdo129 Build thread - TVS1900, EPS cam and more
Old Feb 9, 2011 | 02:21 PM
Preston129's Avatar
Default Preston129 Build thread - TVS1900, EPS cam and more
Hey guys, I've got this thread running on another forum that isn't getting too much traffic so I decided to start it over here, where I'm sure a few more ppl will find it useful and hopefully generate some discussions.
I'll update as often as I can, but for the next couple months not too many wrenches are gonna get turned; we're in the middle of winter so all I'm doing is buying parts, which I'll post up as they come in. Hope you guys enjoy.
I'll start off with some background on the truck:
2007 GMT900 crew cab 4x4
5.3
4L60E
3.73:1 gears
Engine
K&N Aircharger Kit 63-3058
90mm LS3 Throttle body 12605109
Exhaust
Gibson 3" SI/DO cat-back 65628
Transmission
Vette Servo
Circle D 3200 278mm torque converter
Suspension
GroundForce 2/3 drop
Body
Painted bumper bar
GM colourmatched grille
Painted front bowtie
Debadged
De-molded
20% Solar Guard tint on front two windows
Lighting
LED interior dome lights (Recon 3x4 arrays)
6000K HID lows and fogs
Relay harness
V-LEDS 6000K 92-LED switchback front turn signals
Recon smoked tail lights
V-LEDS 5000K 92-LED reverse lights
licence plate lights (Recon 194)
Here are some semi-recent pics:
Old Feb 9, 2011 | 02:26 PM
Preston129's Avatar
The plan of attack for the spring is mostly engine work and some supporting hardware. I'll go into more detail about all the parts involved a bit later, but here are the goals I have in mind for this summer:
Engine
TVS1900
Blower cam and AFM delete
Tune
Exhaust
American Racing 1 7/8" long tube headers and catted y-pipe
Eventually fab up a 3.5 or 4" cat back but this can wait
Rear end
Detroit Truetrac
Suspension
Rear sway bar - Either DJM or Hellwig, not really a top priority for this summer
New rear shocks - Maybe belltech, again, not a priority
I'll post some pics and part numbers later when I get home.
Old Feb 9, 2011 | 04:50 PM
Swerve7rpm2000's Avatar
Nice ride man i love those rims, keep us updated!~
Old Feb 9, 2011 | 06:43 PM
Preston129's Avatar
Thanks man, appreciate it!
Old Feb 9, 2011 | 07:49 PM
Preston129's Avatar
Parts List
I'm going to keep this post to update the parts I've bought, or if I decide to change things, I'll use this as the master parts list.
I originally thought I was going to be building a N/A combo, so I started buying parts about a year ago for that goal in mind, then just recently I got lucky at work getting a few good contracts, then all of a sudden a blower combo sounded very attainable. So if you look through my parts list and think, "WTF, that's a terrible choice for a blower combo", I probably agree with you and all the parts I highlighted in blue are those I haven't yet purchased and are going into my blower build.
Valvetrain/DOD Delete
Part MFR. P/N
LS7 lifters GM 12499225
Lifter trays GM 12595365
GM valley cover GM 12570471
LS2 3-bolt Camshaft gear GM 12586481
LS2 Timing dampener (wedge) GM 12588670
Beehive valvesprings PAC 1518 - to be replaced by:
Dual valvesprings Patriot Dual Xtreme .660" - BOUGHT
Hi-Tech pushrods 7.35 Comp 7950-16
Hi-Tech pushrods 7.425 - Might need new pushrods, need to measure to be sure - BOUGHT
Lightweight tool steel retainers Comp CCA-1772-16
Valve locks Comp CCA-623-16
1.250 Spring Shim Kit Comp CCA-4753
1.7:1 Rocker Arms GM 10214664
Trunion bearing upgrade Comp 13702-KIT
Cam
Part MFR. P/N
EPS LS N/A Cam - to be replaced by:
EPS LS Blower Cam - BOUGHT
Gaskets
Part MFR. P/N
O-ring seal for LS Oil pump
pick-up tube (red) GM 12584922
MLS Head gaskets GM 12589226 - to be replaced by:
LS9 Head gaskets GM 12622033 - BOUGHT
Exhaust manifold gaskets GM 12617944
Engine Front Cover Gasket GM 12574294
Water Pump Gastket GM 12588372
Front Oil Seal GM 12585673
Bolts/fasteners
Part MFR. P/N
Cam retainer bolt kit ARP 134-1002
Camshaft gear bolt kit ARP 134-1003
Cylinder head bolts ARP 134-3610 - to be replaced by:
Cylinder head studs ARP 234-4317 - BOUGHT
Harmonic Balancer bolts ARP 234-2503
Head bolt thread chaser ARP 912-0011 - BOUGHT
Split Lock Friction Lock Header Bolts Percy's PHP20008 - BOUGHT
Electrical
Part MFR. P/N
NGK BR7EF Spark plugs - BOUGHT
MTI Racing spark plug wires - BOUGHT
Fuel system
Part MFR. P/N
Not sure yet, going to do some thinking
Misc
Part MFR. P/N
Rev Xtreme Catch Can RX LS6NA
Trick Perf water reservoir - ORDERED
Livernois CNC LS Rocker stand
Kurt Urban LS cooling system
Intake
Part MFR. P/N
Lingenfelter 100mm MAF - BOUGHT
4" straight silicone coupler
4" hump silicone coupler
Exhaust
Part MFR. P/N
1 7/8" headers + 3 1/2" catted Y ARH GMT0778W/C - BOUGHT
3.5" extension pipe GM or Gibson - BOUGHT
3.5" muffler Magnaflow 14161 or Borla 40086 - BOUGHT
Band Clamps - BOUGHT
Ceramic coating on all exhaust parts - CeramaKrome from RLD Industries (local shop)
Driveline
Part MFR. P/N
FLT 4L60E (level 6 maybe) or Performabuilt lvl 2 or 3
Circle D Pro III 258mm 2B stall speed
Rear end
Part MFR. P/N
Truetrac - BOUGHT
Mag-Hytec 10-85 Cover - BOUGHT
ARP ring gear bolts 230-3001 - BOUGHT
Main cap studs - Either Moser's kit MSR-7115 or T/A's kit TA-1815 - BOUGHT
Old Feb 9, 2011 | 08:03 PM
Preston129's Avatar
Some pics, nothing too exciting so far, mostly just N/A stuff.
One of many boxes of parts sitting in my basement
EPS N/A grind cam
LS7 lifters, soaking in oil
REV Xtreme catch can
PAC 1518, also soaking in oil
Old Feb 10, 2011 | 03:13 PM
fortplainman's Avatar
subbed!
Old Feb 10, 2011 | 03:29 PM
iamkeniff's Avatar
yeah you need 7.425" without milling your heads.
i run 7.4" on a milled .020" L92 head, even though i really need 7.405" but no one makes that size, so i went 7.4
the 7.35" will be too short.
keep up the good work buddy. also have the snout machined down for a smaller pulley just saying more Boost would be sweet
Old Feb 10, 2011 | 11:18 PM
budhayes3's Avatar
PT's Slowest Truck
Nice build man, what are the specs on the EPS cams that you had before and have now?
Old Feb 11, 2011 | 02:14 PM
Preston129's Avatar
Nice to have you on board man,
Ya I realize now the 7.35s are too short, wasn't thinking about the smaller base circle on the cam at the time. And since it's been a long *** time since I bought em I can't exchange, but I'll try to flip them when this build is over, should have a few more N/A parts for sale too.
And I guarantee I'll never pulley down any further than a 3.2 on this poor little 5.3...Think I'm getting a 3.5 pulley in the kit, and I'll see where I'm at with boost and fuel and go from there.
Thanks man, glad to have your expertise on board too.
The N/A one is 219/227 .595 .598 113+3. I haven't picked out the blower one yet, but I think it'll be around 215/231 .600 .604 117. Might tweak that a little and see where Geoff wants to put the valve events, but it's pretty much what I want to see in a FI cam for cathedral ports; wide split favoring the exhaust side and a big LSA to keep cylinder pressures high.
