Petro's Project ERL Superdeck 427 w/ Whipple 2.9L
Old Jul 10, 2017 | 02:11 PM
  #401
Vortec350ss's Avatar
What crank is your spare?
Old Jul 10, 2017 | 02:24 PM
  #402
Petraszewsky's Avatar
Not really a spare I guess...it's just a OEM LS2 crank that I've been practicing on before I do stuff to my Compstar crank. I've been testing most everything on stock LS2 parts before I do it to my nice stuff.
Old Jul 10, 2017 | 08:38 PM
  #403
skolman91's Avatar
This thing isnt together yet? Chop chop get it running so u can yank it and take it apart again so we can see how all this stuff youre doing holds up...lol
Old Jul 10, 2017 | 08:51 PM
  #404
Getting close! I tried posting a video of me spinning the wrist pin for about 15seconds (I've gotten solid 20second spins on it) but imgur is saying it doesn't support the file. I'm fairly confident they'll all still be there when I tear it back apart after a couple thousand miles.
Old Jul 11, 2017 | 03:03 PM
  #405
Bearing and valve coated with mircoslick and tungsten left .....uncoated valve and microslick coated bearing right
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-kqvspqv.jpg
Old Jul 12, 2017 | 12:42 AM
  #406
Blown06's Avatar
8 Second Truck Club
I believe Microblue applies it with air. Not sure if it is a high or low pressure system.
Either way, he made the comment to us several times that once the product was on, it was impossible to remove by any conventional means...
Some of the **** rinsed right off in my parts washer. I was a little more than disappointed in his entire job.
Old Jul 12, 2017 | 10:49 AM
  #407
Yeah they use high pressure blasting (they call it impingement) to apply the tungsten. It probably washed off the extra residual tungsten as it doesn't not adhere to itself. It goes on 1micron thick (.00004"-.00005") And I agree that it is impossible to remove from the substrate unless you blast, machine, abraded the surface. Strong bases or acids will remove it but normal oils , fuels, cleaners etc won't. Even a strong cleaner like acetone won't remove it. The thing with Mircoblue is that they don't use any binders like how the Cerakote Mircoslick does. Mircoblue also REM polishes the parts which just enhancess the WS2. Hell they use it spacecraft bearings etc. I just mixed a little of the tungsten powder with a few ounces of oil and squirted it the crankcase of my Silverado. At .6micron the filter won't catch it. It should burnish itself into the moving parts.
Old Jul 12, 2017 | 11:17 AM
  #408
wretched73's Avatar
Have you torn down that bike at all to see how the microblue has worked?
Old Jul 17, 2017 | 01:39 PM
  #409
Filed a groove to pressure feed the rear thrust face...
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-iikbpnh.jpg
Here's a better pic of the uncoated and coated rings
Petro's Project ERL Superdeck 427 w/ Whipple 2.9L-lskkfgf.jpg
Old Jul 17, 2017 | 01:54 PM
  #410
I dont really understand the benefit of coating the rings?
