Oakley's History Lesson and Build Thread
Old Sep 29, 2014 | 06:25 PM
  #711
Tydriver's Avatar
My bad, I was talking about your "STOCK" NNBS intake that you said was for sale.. What do you want for it?...
Old Sep 29, 2014 | 06:33 PM
  #712
oakley6575's Avatar
Oh sorry dude. Let me get the throttle body on it and find the injectors and I'll let you know how much. I want to make sure I still have everything for it. From what Ive seen recently, they usually go for $250 shipped when they are complete.
Old Sep 29, 2014 | 07:36 PM
  #713
Tydriver's Avatar
OK, don't sweat the injectors, if I go that route I will probably go up to 60's anyhow so all I'm really looking for is the TB and Intake. Thanks,
Old Sep 29, 2014 | 08:21 PM
  #714
oakley6575's Avatar
Okay tomorrow I take some pics of the intake and send you a PM
Old Sep 30, 2014 | 09:11 AM
  #715
69Camaro427's Avatar
Finally haha intake looks beautiful man. Where you going to run your 87-90 mm tb or go 102?
Old Sep 30, 2014 | 12:13 PM
  #716
oakley6575's Avatar
I'll be running my 90mm throttle body. I think the 102 upgrade isn't very cost effective for my set up and goals. I'm waiting on the meth stuff to show up before I make a summit order. So looks like I could be down for a good week or two.
Ive been doing a lot of research and I like the AEM methanol controller the best. You can use the internal map sensor in the controller or wire an aftermarket map sensor in. It also uses a single LED in the cab to show when the pump comes on, pump intensity, any errors, ect. It has a methanol solenoid control built in and a boost safe feature that is pretty cool. If there are any errors like running out of methanol, bad pump, ect, you can wire it to shut off your boost controller to run only the spring pressure in the gate, or to cut timing, or really anything that can be controlled with a ground. Has a lot of good features for only $125.
Old Sep 30, 2014 | 03:02 PM
  #717
Yeah good point with it being a 4.8L and the throttle body costing $4-550.
Now it might make a difference on that 408 of yours later down the road?
Did you decide if you were going back to 3.42s or not?
Old Sep 30, 2014 | 03:09 PM
  #718
oakley6575's Avatar
I think I will put the 3.42's back in after the track closes. I'm on the freeway most of the time to and from work so it just makes sense for me to be cruising at 2000rpm vs 2500rpm.
Old Sep 30, 2014 | 03:12 PM
  #719
53bowtie's Avatar
What traction mods did you end up doing? You can just refer me to the post or page number if you like. I am sure I missed it somewhere.
Old Sep 30, 2014 | 03:16 PM
  #720
oakley6575's Avatar
I am using the assassin bars from smith race craft. They are badass
