Oakley's History Lesson and Build Thread
Old Sep 15, 2013 | 12:24 PM
  #121
oakley6575's Avatar
Here is another pic from Rick. Passenger side crossover to clear the 4" DP. Looks like the kit is coming along good so I am going to order injectors monday. I think FIC 850cc will get the job done. They flow 980cc or 93.3lb/hr at 4 bar. Should be plenty for pump gas and meth to reach 800rwhp and then some.
Right now I have a catch can in between my LS6 valley cover and intake mani. From my reading, I should get rid of the catch can and just vent the two valve covers. I bought two K&N filters but the drivers side filter is way to big to clear the coil brackets. Here is the one I tried to use. 3" diameter http://www.summitracing.com/parts/knn-62-1070. What size filters are you guys using to push in the drivers side valve cover?
When I get home tuesday, I will tear the intake off of the engine to plug some vac sources, route the vac block, relocate my fuel pressure regulator and do a little bit of clean up.
Old Sep 18, 2013 | 08:20 PM
  #122
oakley6575's Avatar
Rick got the turbo in and they sent him a T6 housing . So a .90 A/R T4 housing is in route to him. Getting tired of my truck just sitting there so I decided to work on what I can. I ordered FIC 850cc injectors today so i took the intake off the engine to reroute some things and make it easier to swap injectors. I mounted the 3 bar map to the back of the intake manifold, moved my fpr back to where it was when I had the carb'd 383, and mounted my vacuum manifold to the pcm cover.
Next I'll add my boost gauge in place of the nitrous pressure gauge. After that I'm screwed until the kit shows up.
Old Sep 20, 2013 | 03:43 PM
  #123
oakley6575's Avatar
Got the FIC 850cc injectors in today. There is about a 5mm height difference (FIC injector on the left). Fits the rails and manifold fine. Just need to contact FIC to get the injector data. I need to plug the stock map sensor hole and main PCV hole in the intake mani. Anyone have any suggestions on what to use?
Old Sep 20, 2013 | 05:25 PM
  #124
Lookin good...what diameter is the crossover pipe?
Old Sep 20, 2013 | 05:49 PM
  #125
oakley6575's Avatar
The crossover is 2 1/2". Looks big to me in that pic
Old Sep 20, 2013 | 05:57 PM
  #126
My next mod will be the s475 and another fuel pump. I think the mp70 is maxed on my setup at 13.5 psi. I have a 3.5'' downpipe and a 4'' core intercooler with 3'' cold pipes. Cant wait to see some vids.
Old Sep 20, 2013 | 06:25 PM
  #127
Choda's Avatar
great thread and build man. I love it
Old Sep 21, 2013 | 08:17 PM
  #128
oakley6575's Avatar
I can't wait to make vids Shouldn't be too long
Thanks man!
Old Sep 23, 2013 | 08:58 AM
  #129
slowmo934's Avatar
Great build! I'm also working with Rick now on my stage 4 with a 7675 and 3.5 DP. I'm going from a sts kit and I was wondering what the vacuum manifold you have is used for? This is not the first time I have seen this on a build and I'm becoming curious. Thanks
Old Sep 23, 2013 | 09:11 AM
  #130
milkey57's Avatar
Looking good, those injectors will be plenty, im running them and have plenty of room (gas not e85). good luck getting her together!
