Next stage
Old Jun 21, 2017 | 02:51 PM
  #241
BlackGMC's Avatar
Resident Retard
So far it's running good. I got it good and heat soaked yesterday, hot oil pressure is mid 30's at idle in park. By 3000 rpm it's 60 and I've only had it up to 5600rpm so far and it was 72psi.
I can feel it getting stronger with every drive. Haven't went 100% throttle yet but it appears I lost about 1psi boost. Not sure how long to wait before doing a full wide open pull. I've just been putting good heat cycles on it and varying load and boost. I'll drain the second batch of oil at the 100-200 mile mark and then run another batch of break in till 500.
Nice!!! I am glad is it going well!
Old Jun 22, 2017 | 01:24 AM
  #242
Blown06's Avatar
8 Second Truck Club
Ya. I gave it a couple wide open pulls last night. I talked with TSP as they built the short block and they said after a good heat cycle and oil change let it rip. So I did. Working on the tune, it really seems to like timing.
The 2.8 pullley is giving me around 15psi
Be careful with that timing ****. Mine picked up mph every degree I added and the plugs never showed any signs of even getting close to too much timing. Mine was floating the heads around long before the tune up got anywhere close to being on the edge of max power.
Old Jun 22, 2017 | 05:26 AM
  #243
03sierraslt's Avatar
No doubt. Right now I am still not pushing it as hard as I did my LQ4, I just had the tune conservative until it got some time on it. Being a 100% new motor I wanted it safe and have starting working it back to where it should be.
Old Jun 22, 2017 | 10:15 AM
  #244
mikealicious2k5's Avatar
In for vids of WOT pulls.
Awesome build dude.
Old Jun 28, 2017 | 06:34 AM
  #245
Engine is nice and quiet, it's running well. It's very torquey considering the cam size. It's had a handful of wide open pulls so far, no videos though. The 2.8 pulley is showing close to 15psi. I need to build a 5" intake now to better feed the 102mm
Old Jun 28, 2017 | 08:01 AM
  #246
flatblack83's Avatar
Looks and sounds great, how long till you put the small pulley on..?
Old Jun 28, 2017 | 08:07 AM
  #247
Not sure. Gonna at least get 500 miles on it first.
Old Jun 28, 2017 | 08:13 AM
  #248
oakley6575's Avatar
Small pulley? How much boost are you shooting for?
Old Jun 28, 2017 | 09:59 AM
  #249
All of it. The most this 2300 will do. I can drop two pulley sizes and add a 5" inlet. Between the two should see 2 maybe 3psi
Old Jun 28, 2017 | 10:09 AM
  #250
I think this winter I am gonna put a stand alone tank and nitrous kit on it. A 100 shot should do it well.
