Next stage
Old May 2, 2017 | 07:51 PM
  #221
03sierraslt's Avatar
Originally Posted by GMCtrk
the trans cooler ruptures, not the radiator core.
Yes, what he said. Don't want to wipe out my Billet 80e and get trans fluid all through my new motor. Mainly I wanted more cooling, it's very hilly in western pa and when my temps go up and down at highway speed based on hills I want more cooling. Nothing durastic but they would oscillate here on the highway. Then I go out to Ohio where it's flat and they are steady
Old May 2, 2017 | 07:53 PM
  #222
Yes, what he said. Don't want to wipe out my Billet 80e and get trans fluid all through my new motor. Mainly I wanted more cooling, it's very hilly in western pa and when my temps go up and down at highway speed based on hills I want more cooling. Nothing durastic but they would oscillate here on the highway. Then I go out to Ohio where it's flat and they are steady.
Granted that's when it's hot, when it's 90 here and 95% humidity things get warm. I know it's not Texas heat but the humidity is a bitch. I've been all around the world and I'll take dry heat over humidity any time.
Old May 3, 2017 | 12:49 AM
  #223
TxGC's Avatar
What catch can and fitting on valve cover are you using?
Old May 3, 2017 | 04:20 AM
  #224
Mighty Mouse Solutions.
Old May 9, 2017 | 07:53 PM
  #225
Some progress, not much but hey whatever. Got a lot of other **** to do besides work on the truck.
Old May 9, 2017 | 07:57 PM
  #226
Gotta bleed brakes ( all new lines and new front calipers)
Pre lube motor
Install most of driveline (trans, tcase and dshaft)
New rad is in, coolant is filled and pressure tested.
I made new upper mounts for it, the mounts they have on it are kinda a joke imo.
Old May 9, 2017 | 08:23 PM
  #227
lxcoupe's Avatar
Man it's probably been said before but those steam lines are a work of art.
Old May 9, 2017 | 08:48 PM
  #228
Thanks. I was determined to come up with something going into this project and it worked out good. I like the end result. Not much room with the TVS.
Old May 9, 2017 | 10:08 PM
  #229
MikeGyver's Avatar
Everybody knows that you don't want to finish so you'll never have to get it dirty.
Old May 10, 2017 | 05:29 AM
  #230
True story.
