My turn. lq4/4l80 swap(GOING BOOST PG. 4)
Old Jan 14, 2013 | 08:57 PM
  #21
kelsey_canard's Avatar
Originally Posted by kelsey_canard
Another little update.
I'm still trying to figure out what I'm going to do for the trans wiring. Is rather do the 60e tune, because I will not have to perform a segment swap, but I cannot find much information on how to do all the wiring.
Originally Posted by kyle's v
There's a thread on ls1truck.com that goes into great DETAIL on everything for the 4L80 swap. I'll try to post a link up.
Just re read everything on that thread and there is no information on wiring the 80e to run on the 60e tune. I have found the information on wiring the 80e for an 80e segment swap.
Old Jan 14, 2013 | 09:20 PM
  #22
javzh's Avatar
when i was about to do my 80e swap i was doing some searching and found this thread
read post #54. the rest of the thread is mainly arguing about internet rights
https://www.performancetrucks.net/fo...-486918/page6/
Old Jan 14, 2013 | 09:34 PM
  #23
Ah! Thank you very much. I saw the thread, but could not keep up with it because of all the unrelated arguing going on in it.
So, if I follow the diagram posted below(wiring swap and relay install), is that all that i need to do to run my 80e on the 60e tune? I saw that some codes needed to be deleted, but thats no big deal. What about the ISS?
Old Jan 15, 2013 | 07:59 PM
  #24
Well I'm conviently waiting on my oil tube pickup o ring from the dealer. Got to love dealing with the dealership.
Old Jan 16, 2013 | 05:52 PM
  #25
I grabbed both o rings because I wasn't sure what revision I needed. Should i use the blue or red. Its a iron headed 2000 6.0. What's the best way to install these without pinching them? Put it on the pickup tube first?
Old Jan 27, 2013 | 07:50 PM
  #26
Big update. Got the motor and trans in and running. Here's an idle clip I took.
https://www.youtube.com/watch?v=pACI...e_gdata_player
Its been a while since I updated. I've been working like mad man trying to finish it. I did run into a few problems.
Trans wiring issue:
https://www.performancetrucks.net/fo...03#post5057703
Exhaust fitment:
https://www.performancetrucks.net/fo...01#post5057701
Still have a few issues that I need to work out. 1.) A tune, but I can handle that. 2.). The trans yoke. I used the 5 inch yoke. And just under 2 inches was sticking out. Will this be good enough? 3.). I noticed the valve seats weren't sealing when I swapped valve springs. 3 intake ports leaked and one exhaust port leaked. The valves still held up when I changed the springs, but I am a little worried about it. How can I tell if this is bad enough to affect performance?
Old Jan 27, 2013 | 09:40 PM
  #27
custm2500's Avatar
Ph.D. in HUBRIS
Found that the driver side exhaust manifold had been off before. The exhaust manifold bolts were broken off in the head in the front and back.
The Manifold was not off before. The studs regularly brake. I doubt anyone messed with them.
Sorry if someone else said this didn't see it in the thread.
Old Feb 8, 2013 | 04:51 PM
  #28
A little follow up. I've been driving the truck for about 3 weeks. Everything is good so far. It's burning a little oil, going to put some valve seals on it tomorrow. The trans feels like a tank. An 80e swap should have been my first mod.
Old Feb 8, 2013 | 06:49 PM
  #29
oakley6575's Avatar
Which pick up o ring did you use? Did your pickup tube have the indentation against the flange?
Old Feb 8, 2013 | 06:54 PM
  #30
I used the blue one. The red one did not have a chance of going on. It didn't really have an indentation, almost like a loose fitting flange around the tube that bolted to oil pump.
